In the 51422 Prod Spec v2.0 it states that “high performance RF capacitors” for the X7R decoupling caps should be used.
- Is High performance RF equivalent to a “High-Q”? If that is correct then what sort of Q value would be appropriate for this application? If this is not correct, how is “high performance RF” specified - (any easy way to communicate this to a manufacturer/supplier)?
- In looking at ceramic cap datasheets, the maximum frequency usually stated is 1000MHz (even for RF series caps). What frequency range is required for the decoupling caps? If the frequency range is in fact 2.4GHz, then could someone give me an example part number for a cap because I all can turn up is 1000MHz which is less than half 2.4GHz.
- Also, I’m curious why it’s not stated that the NP0 caps for the xtals and, especially balun should not also be “high performance RF capacitors”. My guess is that class 1 / NP0 is already High performance, or do I need to specify this to the manufacturer as well?
At the risk of making this thread too complex: what exactly are DEC1 and AVDD? They are related to the radio but I can’t find anything specific on what they are used for or how AVDD is different from VDD. The reason I ask is because the value of the AVDD cap is 100 times less than the other decoupling caps.
