Watchdog while in sd_app_evt_wait
Hi
I've discovered last week some unexpected resets by the watchdog. I guess I've the explanation and the workaround for the behavior, but it would be great to have this assumption confirmed. Maybe some other peoples have similar behaviors.
The firmware is built on SDK11 and is based on a simple peripheral project. We have a watchdog configured with a time of five seconds and not running in sleep mode. We establish a connection from a smart device and than do no real data transfer. The call of sd_app_evt_wait by the application never returns, because the application has nothing to do (no interrupt causing the wakeup). After around 80 seconds the system resets caused by the watchdog.
My assumption is, that the softdevice internally wakes up for handling the BLE connection intervals. These ISR's are quite short, but the Watchdog counts up a bit at any wakeup. The application won't reset the watchdog because the call of sd_app_evt_wait never returns.
The solution I have is to configure at least a timer that forces the function sd_app_evt_wait to leave from time to time.
Can someone confirm this behavior? What is the best way to work around it?
Regards Adrian
  • yes that's right - and 5/80 sounds like about the right kind of duty cycle too, depends a bit what you're doing, just advertising it would be much longer, in connection it's working harder.
    And the correct solution is to have your own timer to feed the watchdog.
