By default the UUID 2A00 (Device Name) has the access Permission Write and Read i would like to change it to Read only. How can i do this?
The write permission for the device name is set with the sd_ble_gap_device_name_set() function, when setting the device name. Excerpt from the ble_app_hrs example in SDK 11:
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
Write permissions are set to the variable sec_mode using the BLE_GAP_CONN_SEC_MODE_SET_OPEN() macro. See the documentation for sd_ble_gap_device_name_set() and the list of GAP attribute security requirement setters for the function parameters and available security modes.
To get no write access you should use the BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS() macro.
Regards, Terje
