point to multipoint with UART (multilink on the S120)
I'm interested in using BT LE to collect data from a number of serial based devices -- a point-to-multipoint configuration. I'm familiar with the UART examples and have seen the multilink example.
The "devices" would be connected to a BT "remote" via the UART (+ level shifter etc), any serial traffic needs to be sent over the BT LE link to a single master BT device connected to a PC which can read the data (probably via the UART again).
However, I'm not 100% sure of the model, maybe it's just the terminology. In the multipoint example, there is a central (Softdevice 120) and peripheral (Softdevice 110). The central connects to the peripheral(s) to collect data, which is the opposite to how I need it to work (or is this just convention and can either end initiate the xfer?).
Finally, what are the limitations, I think the multipoint allows up to 8 simultaneous connections, can I have more "parked" connections? i.e. how many device+BTLE "remotes" combinations can I associate with a single BT LE master? (even if only 8 can communicate concurrently).
Thanks!
