TLDR: My dongle has stopped functioning. I think something was corrupted during a j-link update. I'm trying to restore functionality to the device by reflashing the master emulator firmware. When trying to flash the MEFW_nrf51822_0.11.0_firmware_1M.hex image, I receive the error "Failed during parse". I have another dongle which still works fine.
- J-Link v5.12
- Master Control Panel 3.10.0.14
- The dongle is correctly identified in Windows Device Manager (JLink CDC UART Port)
- nRFgo Studio correctly finds the device. I used the "Erase All" command to erase the dongle
- Master Control panel only displays the device's COM port if "File > Options > Show all serial ports" is selected
- I'm using "File > Flash Programming..." in MCP to flash the device
- I've tried all available MEFW firmware images in the /firmware/pca10000/ directory. They all fail with the following message:
nrf6310_cli.exe -p "C:\Program Files (x86)\Nordic Semiconductor\Master Control Panel\3.10.0.14\firmware\pca10000\MEFW_nRF51822_0.11.0_firmware_1M.hex" -snr COM40
Programming started.
Failed during parse
UPDATE (SOLVED):
Following a suggestion below, I ran the following commands, one of which failed:
C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin>nrfjprog --memrd 0 -f nrf51
0x00000000: 20003140 |@1. |
followed by
C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin>nrfjprog --memwr 0 --val 0 -f nrf51
Parsing parameters.
ERROR: The area to write is not erased.
I tried programming via MCP again and received the same error, "Failed during parse". However, I then programmed the device with nrfjprog and, like previous attempts, it reported success, but this time the device was successfully recognized by MCP. I can't say for certain what exactly fixed the problem, but there it is.
nrfjprog --eraseall
nrfjprog --family NRF51 --program MEFW_nrf51822_0.11.0_firmware_1M.hex --verify
nrfjprog --pinreset
Output:
Erasing code and UICR flash areas.
Applying system reset.
Parsing hex file.
Reading flash area to program to guarantee it is erased.
Checking that the area to write is not protected.
Programing device.
Verifying programming.
Verified OK.
Applying pin reset.
