Radio Notifications become inverted
If I have a high-priority interrupt (or a series of them) that runs long enough to completely mask a radio notification, then all further radio notifications appear inverted. Program architecture aside, is there any way I can definitely tell whether a notification is an ACTIVE or a nACTIVE? It's very troublesome when I get it wrong.
As an aside, is there any reason I can't have the radio notification run at priority 0? By definition it will never run at the same time as the lower stack, so it seems like I should be able to make it high priority. And by the same token, is there a reason I can't use priority 2? I can use priority 1, meaning I'm allowed to interrupt the upper stack—any reason I can't just use priority 2 as well?
Alternatively, is there any way I can make SWI1 take priority over ADC if both interrupts want to run?
Thanks!
  • Unfortunately there's no proper way to distinguish between ACTIVE and nACTIVE. I understand that this can be frustrating, I am forwarding this internally to see if anything can be done.
    In general the interrupt that is triggered first is the one that is handled first. If you have two equal priority interrupts firing at the same time, the one with the lowest ISR number will be handled first.
    If a radio notification event does not get handled and another one gets triggered they should become nested, ie. you should get back to back ACTIVE and nACTIVE events (if you have blocking interrupts this could happen at any time from the actual radio event). Are you seeing anything to indicate that this nesting fails, possibly the nesting vector could become full and overflow.
    The most reliable way I can think of is to have radio notifications trigger at a higher priority than the other tasks you want to do. If that is impossible in your application, you might be able to use the scheduler, which we have a tutorial for here.
    Øyvind
  • I don't really have a better explanation than that this is how it is implemented, there's more info on the infocenter for nRF51 and nRF52. The nRF52 is using an M4F processor and has access to more priorities.
