encryption of application code
I wish to encrypt my application to protect my code. I've tried running my hex file through openssl
openssl enc -aes-128-ofb -nopad -nosalt -e -K XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX -iv XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX -in app_release.hex -out app_release_enc.hex
I then try to generate a package as follows :
rfutil dfu genpkg --application app_release_enc.hex --application-version 14 --bootloader bootloader_release.hex --sd-req 0x81,0x00 --softdevice s132_nrf52_2.0.0_softdevice.hex --dev-revision 1 dfu_release_enc.zip
But I then receive the following :
Traceback (most recent call last): File "/usr/local/bin/nrfutil", line 9, in load_entry_point('nrfutil==0.3.0', 'console_scripts', 'nrfutil')() File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 716, in call return self.main(*args, **kwargs) File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 696, in main rv = self.invoke(ctx) File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 1060, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 1060, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 889, in invoke return ctx.invoke(self.callback, **ctx.params) File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 534, in invoke return callback(*args, **kwargs) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/main.py", line 236, in genpkg package.generate_package(zipfile_path) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/dfu/package.py", line 189, in generate_package Package.normalize_firmware_to_bin(work_directory, firmware[FirmwareKeys.FIRMWARE_FILENAME]) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/dfu/package.py", line 329, in normalize_firmware_to_bin temp = nRFHex(firmware_path) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/dfu/nrfhex.py", line 63, in init self.loadfile(source, self.file_format) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/dfu/intelhex/init.py", line 241, in loadfile self.loadhex(fobj) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/dfu/intelhex/init.py", line 204, in loadhex decode(s, line) File "/usr/local/lib/python2.7/dist-packages/nrfutil-0.3.0-py2.7.egg/nordicsemi/dfu/intelhex/init.py", line 115, in _decode_record raise HexRecordError(line=line) nordicsemi.dfu.intelhex.HexRecordError: Hex file contains invalid record at line 1
Can anyone help?
Thanks Lee
