how to read adc value through TwI
hello all,
i am a begineer to nordic . i am trying to read adc PCF8591 value through TWI and i want to print the value in UART TERMINAL.
i have written the code. but it is not fetching the values properly. i attached my code also . please say the solution for this.
Thanks in advance.
POGRAM:
#define SCL_PIN 2
#define SDA_PIN 3
#define SLAVE_ADDRESS 0x48
#define 	TWI_READ_BIT   (0x01)
/* TWI instance. */
static const nrf_drv_twi_t twi_instace_pcf8591 = NRF_DRV_TWI_INSTANCE(0);
/*UART buffer size. */
#define UART_TX_BUF_SIZE 256
#define UART_RX_BUF_SIZE 1
/* Indicates if reading operation from PCF8591 has ended. */
static volatile bool m_xfer_done = true;
/* Indicates if setting mode operation has ended. */
static volatile bool m_set_mode_done = false;
typedef struct
  uint32_t LDR;
  uint32_t THERMISTER;
  uint32_t TRIMPOD;
} sensors;
/*UART EVENT HANDLER*/
static void uart_events_handler(app_uart_evt_t * p_event)
    switch (p_event->evt_type)
        case APP_UART_FIFO_ERROR:
//void PCF8591set_mode(void)
//    ret_code_t err_code;
//    /* Writing to MMA7660_REG_MODE "1" enables the accelerometer. */
//    uint8_t reg[2] = {0x01,0x41};
//    err_code = nrf_drv_twi_tx(&twi_instace_pcf8591,0x48, reg, sizeof(reg), false);
//    APP_ERROR_CHECK(err_code);
//    while(m_set_mode_done == false);
/*UART CONFIGURATION*/
static void uart_config(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_events_handler,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
		printf("\r\n UART CONFIGURATION DONE\n\r");
// * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
	printf("\r\n IN TWI_HANDLER\r\n");
uint32_t err_code,count;
static sensors value;
printf("\r\n %d\r\n",p_event->xfer_desc.type);
	switch(p_event->type)
			case NRF_DRV_TWI_EVT_DONE:
				printf("\r\n IN SWICH CASE\r\n");
            if ((p_event->type == NRF_DRV_TWI_EVT_DONE) &&
                (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX))
                if(m_set_mode_done != true)
                    m_set_mode_done  = true;
                    return;
                m_xfer_done = false;
                /* Read 4 bytes from the specified address. */
                err_code = nrf_drv_twi_rx(&twi_instace_pcf8591,0x48, (uint8_t*)&value, sizeof(value));
								//printf("\r\n 1st time done\r\n");
                //read_data(&m_sample);
							err_code = nrf_drv_twi_rx(&twi_instace_pcf8591,0x42, (uint8_t*)&value, sizeof(value));
							 //nrf_twi_rxd_get	(twi_instace_pcf8591);
							printf("\r\n LDR VALUE=%d\r\n",value.LDR);
							  printf("\r\n THERMISTER VALUE=%d\r\n",value.THERMISTER);
							  printf("\r\n TRIMPOD VALUE=%d\r\n",(uint32_t)value.TRIMPOD);
							  nrf_delay_ms(1000);
                m_xfer_done = true;
/*TWI INITIALISATION*/
void twi_init (void)
    uint32_t err_code;
	uint8_t * pdata;
	const nrf_drv_twi_config_t twi_adc_pcf8591_config = {
       .scl                = SCL_PIN,
       .sda                = SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH
		err_code = nrf_drv_twi_init(&twi_instace_pcf8591,&twi_adc_pcf8591_config,twi_handler, NULL);
    nrf_drv_twi_enable(&twi_instace_pcf8591);
		printf("\r\n TWI IS INITIALIZED\r\n");
int main()
	uart_config();
  twi_init();
 //PCF8591set_mode();
	uint8_t reg=0;
    while(true)
        nrf_delay_ms(100);
        /* Start transaction with a slave with the specified address. */
        do
            __WFE();
        }while(m_xfer_done == false);
        err_code = nrf_drv_twi_tx(&twi_instace_pcf8591,0x48, &reg, sizeof(reg), true);
        m_xfer_done = true;
