pwm with use of timer and ppi
hi its not working as i want . y is that?
first step i try to toggle just with one cc that is the code below
with changing of NRF_TIMER2->CC[0] = 65536;nothing happend there is no difrence in changing it
y is that?
    nrf_gpio_cfg_output(PWM_OUTPUT_PIN_NUMBER);
    // Configure GPIOTE channel 0 to toggle the PWM pin state
    // @note Only one GPIOTE task can be connected to an output pin.
    nrf_gpiote_task_config(0, PWM_OUTPUT_PIN_NUMBER, \
                           NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIOTE_INITIAL_VALUE_LOW);
   // Configure PPI channel 0 to toggle PWM_OUTPUT_PIN on every TIMER2 COMPARE[0] match.
    NRF_PPI->CH[0].EEP = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[0];
    NRF_PPI->CH[0].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0];
    // Enable PPI channels 0-2.
    NRF_PPI->CHEN = (PPI_CHEN_CH0_Enabled << PPI_CHEN_CH0_Pos);
    // Start 16 MHz crystal oscillator .
    NRF_CLOCK->TASKS_HFCLKSTART    = 1;
    // Wait for the external oscillator to start up.
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        //Do nothing.
    NRF_TIMER2->MODE      = TIMER_MODE_MODE_Timer;
    NRF_TIMER2->BITMODE   = TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos;
    NRF_TIMER2->PRESCALER = TIMER_PRESCALERS;
    // Clears the timer, sets it to 0.
    NRF_TIMER2->TASKS_CLEAR = 1;
    // Load the initial values to TIMER2 CC registers.
    // Interrupt setup.
    NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos);
void TIMER2_IRQHandler(void)
    static bool cc0_turn = false; /**< Keeps track of which CC register to be used. */
    if ((NRF_TIMER2->EVENTS_COMPARE[0] != 0) &&
       ((NRF_TIMER2->INTENSET & TIMER_INTENSET_COMPARE0_Msk) != 0))
			//NRF_TIMER2->TASKS_CLEAR = 1;
