secure pairing problem with iphone
I have one nRF52822 Ble. It has secure pairing mechanism. when i connect iphone, App trigger Pair dialog from iOS. and press pairing, then stop. i can follow nRF52822 code. after print pair success , it will disconect, disconnected.reason is 0x13. why?
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
    printf("evt id =======%x\r\n",p_ble_evt->header.evt_id);
        case BLE_GAP_EVT_CONNECTED:
			printf("handle BLE_GAP_EVT_CONNECTED event in on_ble_evt()\r\n");
	  ble_gap_sec_params_t params;
         params.bond = 0;
         params.mitm = 0;
		 params.io_caps = 1;
	  sd_ble_gap_authenticate(m_conn_handle,&params);
		      		printf("BLE_GAP_EVT_DISCONNECTED in on_ble_evt(), Reason: 0x%x\r\n", p_ble_evt->evt.gap_evt.params.disconnected.reason);
            // Pairing not supported
            ble_gap_sec_params_t sec_params;
			printf("handle BLE_GAP_EVT_SEC_PARAMS_REQUEST in on_ble_evt()\r\n");
	    memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
	    sec_params.bond = 0;
	    sec_params.io_caps = 1;
	    sec_params.max_key_size = 16;
	    sec_params.min_key_size = 7;
	    sec_params.oob = 0;
	    sec_params.mitm = 0;
	    err_code=sd_ble_gap_sec_params_reply(m_conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
        //    err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        //    APP_ERROR_CHECK(err_code);
        case BLE_GAP_EVT_AUTH_STATUS:
		          if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS){
            printf("pair success\r\n");
          }else{
            printf("pair fail \r\n");
            sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
	case BLE_GAP_EVT_CONN_SEC_UPDATE:
					printf("handle BLE_GAP_EVT_CONN_SEC_UPDATE event in on_ble_evt()\r\n");
            // No implementation needed.
this is all print main.......
QR code name:F13C7DA2AF5A
ble_stack_init() is done.......
device name of GAP = F13C7DA2AF5A
Message:10
handle BLE_GAP_EVT_CONNECTED event in ble_conn_params_on_ble_evt()
evt id =======10
handle BLE_GAP_EVT_CONNECTED event in ble_nus_on_ble_evt()
Message:13
evt id =======13
Message:50
BLE_GATTS_EVT_WRITE event in ble_nus_on_ble_evt()
enter on_write()
p_nus->is_notification_enabled = true
evt id =======50
Message:18
evt id =======18
Message:17
evt id =======17
handle BLE_GAP_EVT_AUTH_STATUS event in on_ble_evt()
pair success
Message:11
evt id =======11
BLE_GAP_EVT_DISCONNECTED in on_ble_evt(), Reason: 0x13
