dfu works, but app wont start after device restart
SDK 11.0.0 SD s132 2.0.1 nRF 52 dev kit
I have been in the process of adding dfu functionality to an existing application.
Currently, I have gotten the dfu to work successfully with the application. I can flash the softdevice and bootloader (I am using the bootloader from the example in SDK 11: dfu_dual_bank_ble_s132_pca10040), and then use MCP on Android to flash the app over bluetooth. The application runs fine and I can connect and reconnect without a problem. However, when I turn the device off and turn it back on, the application does not start, nor does the bootloader start.
I find this strange, because for the HRM-DFU example, the process to update the firmware is: program softdevice ---> program bootloader --->update firmware. and once the firmware is updated, I can turn the device on and off, and it will still advertise in MCP as HRMAPP.
But with my application, when I go through the same process above, once I turn the device off, the device won't advertise anymore neither as APP_NAME or DfuTarg.
I have not seen anyone on the dev zone with a similar problem, unfortunately. I did double-check that I ported the application successfully with respect to this reference, but i do not think this would be a problem since the dfu itself works fine.
thanks for all the help.
