Clarification on S110 SDS "Processor availability and interrupt latency"
I am currently using MBR, and know the general interrupt latency due to MBR + SD from Table 26. But I cannot understand how you arrived at those numbers. IF this table was referring to JUST the MBR caused latency, I think it makes sense--assuming that MBR acts deterministically for EVERY interrupt. But once SD is involved, I do not understand: wouldn't the SD caused interrupt latency change depending on whether there is an outstanding BLE activity? So are numbers in Table 26 just an average? If so, what is the maximum and minimum (therefore the jitter)?
Conversely, I understand that high priority app interrupt will interfere with the BLE upper stack performance. Is there existing doc explaining how long I can take in the high priority app interrupt before I cause a problem?
Thank you very much for reading.
