128-bit characteristic: Discrepancy between tutorial and app note.
I found a discrepancy between a tutorial and an application note.
Step 2.A of "BLE Characteristics, a beginner's tutorial" devzone.nordicsemi.com/.../ calls sd_ble_uuid_vs_add for each characteristic.
Application note nAN-36 www.nordicsemi.com/.../nAN-36.zip
does not call sd_ble_uuid_vs_add for each characteristic. It just re-uses the returned type by the sd_ble_uuid_vs_add call for the service.
ble_uuid.type = p_lbs->uuid_type;
ble_uuid.uuid = LBS_UUID_BUTTON_CHAR;
Which one is correct? Or do they achieve exactly the same under water?
  • I have learned from Carles (Nordic) that effectively this is the same.
    The trick used (and explained in different area's) is that the vendor-specific base UUID is given a type number which then can be used later for vendor-specific service UUIDs and characteristic UUIDs (where only 16-bit of the 128-bits are changed).
    However, due to a bug in an older release, adding an vendor-specific base UUID that was already added earlier results in a error code, thus the approach of the application note works for older releases without generating an error.
