NRF52 DK - Dynamic payload(DPL) and static payload.
I have an NRF24LE1 transmitter using ESB. It is sending a static payload of 10 bytes every sec. The other configurations on the transmitter are: RF channel:2, CRC: 1 byte, DataRate: 1MBPS.
I am trying to understand the given example code for esb_prx for NRF52-DK in NRF5 SDK 11.0. which I am using as Receiver.
It seem dynamic payload length - DPL is used as a default configuration. Can I use dynamic payload to talk to my current transmitter which has static payload ? What is dynamic payload mean, does it mean I can send any number of bytes to the Receiver? If so, payload_length field of nrf_esb_config_t in Receiver become irrelevant in DPL mode.
On a side question about esb_ptx in NRF52-DK:
#define NRF_ESB_CREATE_PAYLOAD(_pipe, ...)                                                  \
        {.pipe = _pipe, .length = NUM_VA_ARGS(__VA_ARGS__), .data = {__VA_ARGS__}};         \
        STATIC_ASSERT(NUM_VA_ARGS(__VA_ARGS__) > 0 && NUM_VA_ARGS(__VA_ARGS__) <= 63)
static nrf_esb_payload_t        tx_payload = NRF_ESB_CREATE_PAYLOAD(0, 0x01, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00);
What will be the pipe number, length and data values using NRF_ESB_CREATE_PAYLOAD macro ? But nrf_esb_payload_t is defined as follows:
typedef struct
    uint8_t length;                             /**< Length of the packet. Should be equal or less than
                                                        NRF_ESB_MAX_PAYLOAD_LENGTH. */
    uint8_t pipe;                                   /**< Pipe used for this payload. */
    int8_t  rssi;                                   /**< RSSI for received packet. */
    uint8_t noack;                                  /**< Flag indicating that this packet will not be
                                                          acknowledged. */
    uint8_t pid;                                    /**< PID assigned during communication. */
    uint8_t data[NRF_ESB_MAX_PAYLOAD_LENGTH];  /**< The payload data. */
} nrf_esb_payload_t;
Does the macro fill all the fields of this structure, if so, what will be the values of each field in this example?
    Dynamic payload means that payload length is configurable for every packet sent.
    In non-DPL mode every payload has to be of pre-determined length.
    I don't believe DPL <-> fixed payload length communication is possible.
    DPL is configured in the nrf_esb_config_t->protocol field, and can take the following values:
    NRF_ESB_PROTOCOL_ESB,      /*< Enhanced ShockBurst with fixed payload length.                                            */
    NRF_ESB_PROTOCOL_ESB_DPL   /*< Enhanced ShockBurst with dynamic payload length.
    What you want to do is configure ESB to run in fixed packet length mode. I think this configuration should be suitable for your scenario:
    nrf_esb_config_t nrf_esb_config         = NRF_ESB_DEFAULT_CONFIG;
    nrf_esb_config.payload_length           = 10;
    nrf_esb_config.protocol                 = NRF_ESB_PROTOCOL_ESB; //No DPL
    nrf_esb_config.bitrate                  = NRF_ESB_BITRATE_1MBPS;
    nrf_esb_config.mode                     = NRF_ESB_MODE_PRX;
    nrf_esb_config.crc                      = NRF_ESB_CRC_8BIT // 1 byte CRC
    nrf_esb_config.event_handler            = nrf_esb_event_handler;
    nrf_esb_config.selective_auto_ack       = false;
    When using DPL the payload_length field in nrf_esb_config_t is ignored, and the length specified in the payload struct is used instead.
  • I think you are referring to nrf_esb_payload_t struct's length field, am i right? Can you give an example for a given DPL length value and the sent packet length value?
    Could you look into my second question about esb_tx as well if possible ?
  • Yes, I was referring to nrf_esb_payload_t struct.
    Not sure what you mean by your second question. In DPL mode, setting nrf_esb_payload_t->length to eg 12 will result in a packet with payload length 12.
    I now see that the doc is unclear here:
    nrf_esb.h line 242: "Length of the packet. Should be equal or less than NRF_ESB_MAX_PAYLOAD_LENGTH."
    This should be:
    "Length of the payload. Should be equal or less than NRF_ESB_MAX_PAYLOAD_LENGTH."
    About the macro, it will only fill the fields data, length and pipe. The other fields will be set to zero according to C spec.
    Should use this as NRF_ESB_CREATE_PAYLOAD(pipe, payload_data)
    So NRF_ESB_CREATE_PAYLOAD(0, 0x0a, 0x0b, 0x0c) will give packet.length=3, packet.pipe=0 and packet.data= {0x0a, 0x0b, 0x0c}
  • In the esb_ptx code, it is given:
    It mean, pipe = 0; length = 8; data[8] = { 0x01, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00 }
    At line no: 149 of main.c, NRF_LOG_HEX_CHAR(tx_payload.data[1]). I think this line is displaying the character in HEX that is to be sent to the Receiver. Is it sending just 1 byte which is data[1]=0x00 instead of 8 byte payload here?
    In the esb_prx, payload_length is given as 8 at line 100 of main.c file. At line 70 of main.c: NRF_LOG_HEX_CHAR(rx_payload.data[1]); It seem to be receiving the same byte that is sent at the Transmitter?
  • This example is always sending 8 byte payloads, but only data[1] is logged and used.
    And yes, it is correct that the receiver is receiving the same byte that is sent at the transmitter. Anything else would not be a very useful protocol :)
