GAZELL Does not work when device is disconnected and reconnected
Hi Nordic.
So, I am using GAZELL to link a sensor node (PCA10001) to a host (PCA1000) When the node is connected is should automatically send its address to the host. this part works fine. The node does send its address and receives and acknowldgement of 0x00 which indicates that It should not transfer more data untill the host has requested it to do so. So on the other side the host will be listining to the user through the UART port awaiting his request. once the user issue a command, it will trigger a uart interrupt and it will be denumerated to a correct ack value and send to the host.
Here is what does not work. When I disconnect the node and reconnect it, it does not show its address anymore. That is even though it send the address to the host, the host fails to collect the data.
Attached are the main c files for the node and the host.
Thanks you in advance.
Raiyan
main_app.c host_main_SW.c
  • @Raiyans: Could you let me know which protocol are you testing ? Gazell pairing or Gazell link layer ? What do you mean by "connected" and "its address" ?
    I don't understand this part:
    "So on the other side the host will be listining to the user through the UART port awaiting his request. once the user issue a command, it will trigger a uart interrupt and it will be denumerated to a correct ack value and send to the host."
    So you have correct ACK value via UART to the host, what would the host do after that ?
    If you try to test with the default example, do you have the same problem ?
  • Hallo Mr. Bui, Thank you for your reply. I have now figured out what the problem was. I was trying to start the communication from the Host side but the communication can only be started from the device. I.e. I will have to implement some sort of a time in the device and after ever pre-defined period of time it should start communication with the host to see if the user has requested some new data. Thank you once more.
    Regards Raiyan
