Advertising issue of BLE and RTC combine code
Hi
I have to combine both BLE UART profile and RTC examples of nrf52 of 11.0.0 SDK for my application.When I run them individually, they are working fine.After combining both examples I am getting problem in RTC initialization.When I put the nrf52 in debugg mode in Keil, i am getting issue in rtc initialization part.
After combining both examples advertising is not happening.Is it the issue of clock frequency?Am i missing something? please give suggestions.
This is the combined code:
		#include <stdint.h>
		#include <string.h>
		#include "nordic_common.h"
		#include "nrf.h"
		#include "ble_hci.h"
		#include "ble_advdata.h"
		#include "ble_advertising.h"
		#include "ble_conn_params.h"
		#include "softdevice_handler.h"
		#include "app_timer.h"
		#include "app_button.h"
		#include "ble_nus.h"
		#include "app_uart.h"
		#include "bsp.h"
		#include "bsp_btn_ble.h"
	#include "nrf.h"
	#include "nrf_gpio.h"
	#include "nrf_drv_config.h"
	#include "nrf_drv_rtc.h"
	#include "nrf_drv_clock.h"
	#include "boards.h"
	#include "app_error.h"
	#include <stdint.h>
	#include <stdbool.h>
	#include <string.h>
	#include <stdint.h>
	#include <stdio.h>
	#include "nrf_delay.h"
	#include "nrf.h"
	#include "bsp.h"
	//====================================RTC===================================================================
	#define COMPARE_COUNTERTIME  (1UL)                                        /**< Get Compare event COMPARE_TIME seconds after the counter starts from 0. */
	#ifdef BSP_LED_2
			#define TICK_EVENT_OUTPUT     BSP_LED_2                                 /**< Pin number for indicating tick event. */
	#ifndef TICK_EVENT_OUTPUT
			#error "Please indicate output pin"
	#ifdef BSP_LED_3
			#define COMPARE_EVENT_OUTPUT   BSP_LED_3                                /**< Pin number for indicating compare event. */
	#ifndef COMPARE_EVENT_OUTPUT
	const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
	uint32_t count=0;
	bool ov_flag=false;
	typedef struct{
		uint8_t second;
		uint8_t minute;
		uint8_t hour;
		uint8_t date;
		uint8_t month;
		int year;
		}time;
	time t,m={0},p={0};
	void start_date(void)
			time m={0};
			time p={0};
			t.second	=10;
			t.minute	=27;
			t.hour		=18;
			t.date		=7;
			t.month		=7;
			t.year		=2016;
			printf("START DATE\r\nDATE =  %d-%d-%d TIME = %d:%d:%d\r\n",t.date,t.month,t.year,t.hour,t.minute,t.second);
	static char not_leap(void)      //check for leap year
	void update_date_time(void)
	void get_time_date(void)
		update_date_time();
	static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
			if (int_type == NRF_DRV_RTC_INT_COMPARE0)
				 // nrf_gpio_pin_toggle(COMPARE_EVENT_OUTPUT);
					//get_time_date();
			else if (int_type == NRF_DRV_RTC_INT_TICK)
					nrf_gpio_pin_toggle(TICK_EVENT_OUTPUT);
					//get_time_date();
			else if (int_type == NRF_DRV_RTC_INT_OVERFLOW)
					ov_flag=true;
					get_time_date();
					memcpy(&t,&p,sizeof(p));				// memcpy (dest_struct, source_struct, sizeof (dest_struct));
					printf("DATE_TIME after overflow\r\nDATE =  %d-%d-%d TIME = %d:%d:%d\r\n",t.date,t.month,t.year,t.hour,t.minute,t.second);
	/** @brief Function configuring gpio for pin toggling.
	static void leds_config(void)
			LEDS_CONFIGURE(((1<<COMPARE_EVENT_OUTPUT) | (1<<TICK_EVENT_OUTPUT)));
			LEDS_OFF((1<<COMPARE_EVENT_OUTPUT) | (1<<TICK_EVENT_OUTPUT));
	/** @brief Function starting the internal LFCLK XTAL oscillator.
	static void lfclk_config(void)
			ret_code_t err_code = nrf_drv_clock_init();
	/** @brief Function initialization and configuration of RTC driver instance.
	static void rtc_config(void)
			uint32_t err_code;
			//Initialize RTC instance
			err_code = nrf_drv_rtc_init(&rtc, NULL, rtc_handler);
			//Enable tick event & interrupt
		 // nrf_drv_rtc_tick_enable(&rtc,true);
			//Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
			//err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME*RTC0_CONFIG_FREQUENCY,true);
			//APP_ERROR_CHECK(err_code);
			nrf_drv_rtc_overflow_enable(&rtc,true);
			//Power on RTC instance
			nrf_drv_rtc_enable(&rtc);
		#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
		#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
		#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
		#define DEVICE_NAME                     "UART_RTC"                               /**< Name of device. Will be included in the advertising data. */
		#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
		#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
		#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
		#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
		#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
		#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
		#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
		#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
		#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
		#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
		#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
		#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
		#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
		#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
		#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
		static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
		static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
		static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
		/**@brief Function for assert macro callback.
		 * @warning This handler is an example only and does not fit a final product. You need to analyse
		 * @param[in] line_num    Line number of the failing ASSERT call.
		 * @param[in] p_file_name File name of the failing ASSERT call.
		 *          the device. It also sets the permissions and appearance.
				uint32_t                err_code;
																							strlen(DEVICE_NAME));
		/**@brief Function for handling the data from the Nordic UART Service.
		 * @details This function will process the data received from the Nordic UART BLE Service and send
		 *          it to the UART module.
		 * @param[in] p_nus    Nordic UART Service structure.
		 * @param[in] p_data   Data to be send to UART module.
		 * @param[in] length   Length of the data.
		/**@snippet [Handling the data received over BLE] */
		static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
				for (uint32_t i = 0; i < length; i++)
						while(app_uart_put(p_data[i]) != NRF_SUCCESS);
				while(app_uart_put('\n') != NRF_SUCCESS);
				uint32_t       err_code;
				ble_nus_init_t nus_init;
		/**@brief Function for handling an event from the Connection Parameters Module.
		 * @details This function will be called for all events in the Connection Parameters Module
		 *          which are passed to the application.
		 * @note All this function does is to disconnect. This could have been done by simply setting
		 *       the disconnect_on_fail config parameter, but instead we use the event handler
		 *       mechanism to demonstrate its use.
				uint32_t err_code;
				if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
		/**@brief Function for handling errors from the Connection Parameters module.
				APP_ERROR_HANDLER(nrf_error);
				// Prepare wakeup buttons.
				uint32_t err_code;
				switch (ble_adv_evt)
						case BLE_ADV_EVT_FAST:
						case BLE_ADV_EVT_IDLE:
								sleep_mode_enter();
		/**@brief Function for the application's SoftDevice event handler.
		 * @param[in] p_ble_evt SoftDevice event.
		static void on_ble_evt(ble_evt_t * p_ble_evt)
				uint32_t                         err_code;
						case BLE_GAP_EVT_CONNECTED:
								// Pairing not supported
								// No implementation needed.
		/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
		 *        event handler.
		 * @details This function is called from the SoftDevice event interrupt handler after a
		 *          SoftDevice event has been received.
		static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
				ble_conn_params_on_ble_evt(p_ble_evt);
				ble_nus_on_ble_evt(&m_nus, p_ble_evt);
				ble_advertising_on_ble_evt(p_ble_evt);
				bsp_btn_ble_on_ble_evt(p_ble_evt);
		/**@brief Function for the SoftDevice initialization.
		 * @details This function initializes the SoftDevice and the BLE event interrupt.
				uint32_t err_code;
				nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
				// Initialize SoftDevice.
				SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
				ble_enable_params_t ble_enable_params;
				err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
																												PERIPHERAL_LINK_COUNT,
																												&ble_enable_params);
				//Check the ram settings against the used number of links
				CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
				// Enable BLE stack.
				err_code = softdevice_enable(&ble_enable_params);
				// Subscribe for BLE events.
				err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
		 * @param[in]   event   Event generated by button press.
				uint32_t err_code;
				switch (event)
						case BSP_EVENT_SLEEP:
								sleep_mode_enter();
						case BSP_EVENT_DISCONNECT:
								err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
						case BSP_EVENT_WHITELIST_OFF:
								err_code = ble_advertising_restart_without_whitelist();
		 *          a string. The string will be be sent over BLE when the last character received was a
		 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
		 *          @ref NUS_MAX_DATA_LENGTH.
		/**@snippet [Handling the data received over UART] */
				static uint8_t index = 0;
				uint32_t       err_code;
				switch (p_event->evt_type)
						case APP_UART_DATA_READY:
								index++;
								if ((data_array[index - 1] == '\r') || (index >= (BLE_NUS_MAX_DATA_LEN)))
										err_code = ble_nus_string_send(&m_nus, data_array, index);
										index = 0;
						case APP_UART_FIFO_ERROR:
		/**@brief  Function for initializing the UART module.
		/**@snippet [UART Initialization] */
		static void uart_init(void)
				const app_uart_comm_params_t comm_params =
						RX_PIN_NUMBER,
						TX_PIN_NUMBER,
						RTS_PIN_NUMBER,
						CTS_PIN_NUMBER,
						APP_UART_FLOW_CONTROL_ENABLED,
						false,
						UART_BAUDRATE_BAUDRATE_Baud115200
				APP_UART_FIFO_INIT( &comm_params,
													 UART_RX_BUF_SIZE,
													 UART_TX_BUF_SIZE,
													 uart_event_handle,
													 APP_IRQ_PRIORITY_LOW,
													 err_code);
				uint32_t      err_code;
				ble_advdata_t advdata;
				ble_advdata_t scanrsp;
				// Build advertising data struct to pass into @ref ble_advertising_init.
				memset(&advdata, 0, sizeof(advdata));
				advdata.name_type          = BLE_ADVDATA_FULL_NAME;
				advdata.include_appearance = false;
				advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
				memset(&scanrsp, 0, sizeof(scanrsp));
				scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
				scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
				ble_adv_modes_config_t options = {0};
				options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
				options.ble_adv_fast_interval = APP_ADV_INTERVAL;
				options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
				err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
				bsp_event_t startup_event;
				uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
																		 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
																		 bsp_event_handler);
		/**@brief Function for placing the application in low power state while waiting for events.
		static void power_manage(void)
				uint32_t err_code = sd_app_evt_wait();
		/**@brief Application main function.
				uint32_t err_code;
				bool erase_bonds;
				// Initialize.
				APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
				uart_init();
				//leds_config();
				ble_stack_init();
				gap_params_init();
				services_init();
				advertising_init();
				conn_params_init();
				printf("\r\nUART Start!\r\n");
				err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
				lfclk_config();
				rtc_config();
				start_date();
				// Enter main loop.
				for (;;)
						power_manage();
