nrf24 as TX and nrf51 as RX: ESB
HI, I have a remote control with nRF24L01. It was talking with Gen1(uses nRF24L01) product via ESB. Now, I am developing Gen2 product*using nRF51822xxaa) and I need to support backwards compatibility with the remote control, in other words, I need to make nRF51 to talk with nRF24L01 via ESB. I am able to receive from nRF24L01(this means, address, crc, addr byte length are correct). But, when I send ack from nrf51 to nrf24 with payload, nrf24 is not receiving it. (when I use two nrf51s, one as tx and the other as rx, they both receive and transmit without any problems). Please help.
This is the init settings for nRF24L01:
hash define RF_CHANNEL      40 //physical channel frequency MHz (2400+RF_CHANNEL)
hash define RF_POWER_DB     3   //0:-18dBm, 1:- 12dBm, 2:-6dBm, 3:0dBm
hash define RF_ADDR_WIDTH   4 //the address is 4 bytes
hash define RF_RETRANSMITS  6   //auto retransmit
hash define RF_RETRANS_DELAY 750    //wait for the ACK (us)
hash  define BROADCAST_ADDR_BYTE1   0x7E
hash define BROADCAST_ADDR_BYTE2    0x7E
hash define BROADCAST_ADDR_BYTE3    0x7E
hash define BROADCAST_ADDR_BYTE4    0x6E
    // Enable the radio clock
    RFCKEN = 1;
    //close all pipes
    hal_nrf_close_pipe(HAL_NRF_ALL);
addr[RF_ADDR_WIDTH] = {BROADCAST_ADDR_BYTE1, BROADCAST_ADDR_BYTE2, BROADCAST_ADDR_BYTE3, BROADCAST_ADDR_BYTE4};
    hal_nrf_set_address(HAL_NRF_TX, addr);
    hal_nrf_set_address(HAL_NRF_PIPE0, addr);
    // Set rf channel 2430
    hal_nrf_set_rf_channel(RF_CHANNEL);
    // Set the RF_SETUP register
    hal_nrf_set_output_power(RF_POWER_DB);
    //hal_nrf_set_datarate(HAL_NRF_1MBPS); //1Mbps data rate
    hal_nrf_set_datarate(HAL_NRF_250KBPS);
    // Set CRC16
    hal_nrf_set_crc_mode(HAL_NRF_CRC_16BIT);
    // Set address width
    hal_nrf_set_address_width(RF_ADDR_WIDTH);
    // Set auto retries(ARC) and delay(ARD, us)
    hal_nrf_set_auto_retr(RF_RETRANSMITS, RF_RETRANS_DELAY);
    // Enable payload with ack and Dynamic payload length
    hal_nrf_activate_features(); //this chip does not need activate, so the func is empty
    hal_nrf_enable_ack_payload(true);
    hal_nrf_enable_dynamic_payload(true);    //dynamic payload length
    // Enable Pipe0 Dynamic payload length
    hal_nrf_setup_dynamic_payload(0x01);
    // Enable pipe0 with auto ack
    hal_nrf_open_pipe(HAL_NRF_PIPE0, true);
    // Set rx payload width to the number of bytes expected
    hal_nrf_set_rx_payload_width(HAL_NRF_PIPE0, RF_PAYLOAD_LENGTH);
    // Flush tx and rx fifo
    hal_nrf_flush_rx();
    hal_nrf_flush_tx();
    // Configure radio as PTX
    hal_nrf_set_operation_mode(HAL_NRF_PTX);
    // Power up radio
    hal_nrf_set_power_mode(HAL_NRF_PWR_UP);
    ptx_check_ack.enable = false;
**This is the init settings for nRF51822xxaa:**
    (void)nrf_esb_init(NRF_ESB_MODE_PRX);
nrf_esb_set_crc_length(NRF_ESB_CRC_LENGTH_2_BYTE);
nrf_esb_set_datarate(NRF_ESB_DATARATE_250_KBPS);
nrf_esb_set_retransmit_delay(2750);
nrf_esb_set_base_address_length(NRF_ESB_BASE_ADDRESS_LENGTH_3B);
nrf_esb_set_address_prefix_byte(0, 0x7e);
nrf_esb_set_base_address_0(0x006e7e7e);
 nrf_esb_set_channel(40);
    // Load data into TX queue
 my_tx_payload[0] = 0xEF;
my_tx_payload[1] = 0xEF;
my_tx_payload[2] = 0xEF;
my_tx_payload[3] = 0xEF;
my_tx_payload[4] = 0xEF;
my_tx_payload[5] = 0xEF;
my_tx_payload[6] = 0xEF;
my_tx_payload[7] = 0xEF;
my_tx_payload[8] = 0xEF;
my_tx_payload[9] = 0xEF;
my_tx_payload[10] = 0xEF;
my_tx_payload[11] = 0xEF;
    (void)nrf_esb_add_packet_to_tx_fifo(PIPE_NUMBER, my_tx_payload, 12, NRF_ESB_PACKET_USE_ACK);
    (void)nrf_esb_add_packet_to_tx_fifo(PIPE_NUMBER, my_tx_payload,12, NRF_ESB_PACKET_USE_ACK);
    // Enable ESB to start receiving
    (void)nrf_esb_enable();
  • @nordicdev: On the other way around can you send ack payload from the nRF24L01 to the nRF51 ? I would suggest you to test with the latest SDK v11, where we have the ESB library open source. You can actually debug inside the nRF51 when it receive a packet to see what would be wrong with the ACK TX packet. You can then compare it with the TX packet when the nRF51 acts as PTX (that works fine).
