I'm looking into using the CMSIS RTOS on the nRF51822 with the S110 softdevice which I've used successfully with other Cortex M0 MCUs. I realize the S110 isn't well tested with various RTOS, but documentation indicates it should be possible.
When initializing the softdevice stack with the call to sd_softdevice_enable(), the return code is 0x0D which nrf_error.h indicates is NRF_ERROR_TIMEOUT. However, the documentation for this function in the header files doesn't indicated this is an expected error to be returned. I'm assuming there is some sort of conflict between the RTOS and the softdevice, but it's unclear what the nature of the timeout might be.
Any hints on where I can look to track down the cause of this issue?
Also, if I get the above issue worked out I'm a bit worried about a conflict between the SVC handling by the softdevice and the RTOS. Since the softdevice controls the SVC interrupt handler, I'm assuming it properly chains the SVC calls intended for the RTOS use. Or, is this a bad assumption on my part.
Mike
