Hello
I am trying to build the nAN-36 application. The main.c file include at least two files that I do not find: #include "ble_eval_board_pins.h" #include "ble_stack_handler.h" Where can I find them or do I make a mistake ?
Thanks
Olivier
Hello
Thanks
Olivier
As is stated in the introduction to this application note, it's written for SDK 4.4.2 and S110 version 5.2.1. If you use SDK 5.1.0, you'll have to modify things somewhat.
ble_eval_board_pins.h have been replaced with just boards.h, and you must make sure to set the BOARD_PCA10001 define. ble_stack_handler is now sofdevice_handler.h, and the init macro have changed as well. I suggest that you compare ble_app_template from SDK 5.1.0 with the application that is attached to nAN-36 to see the differences.
Edit: I just put an updated version of the nAN-36 application out on our GitHub. Take a look here.
Well, it would be great to have this AN upgraded for the new JDK and softdevice version ....
Yessssss, it works now !!! I will try S120 on Eval board tomorrow ....
Olivier
We're actually working on this, so an update should be out in not too long.
You may be interested to know that I put an updated version of the nAN-36 at our GitHub: https://github.com/NordicSemiconductor/nrf51-ble-app-lbs
