SAADC to measure battery voltage not getting proper result
I am new to the SAADC concept in nrf52. I have to measure the battery voltage using SAADC over ANI0 pin. I using battery with voltage 4.1 volt.
This voltage is divided using voltage divider with two resistances of 10 kohm and 3.5 kohm . I am applying 1 volt to the ANI0 pin through this network.
SAADC configuration is the default one with single ended. reference = 0.6volt gain = 1/6
So as per the formula given in datasheet,under this condition I should get ADC output as
((1*(1/6))*256)/0.6=71.11
but i am getting 4 or 5 or 6 as output on UART. following is the code,
    /* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @defgroup nrf_adc_example main.c
 * @ingroup nrf_adc_example
 * @brief ADC Example Application main file.
 * This file contains the source code for a sample application using ADC.
 * @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "boards.h"
#include "app_uart.h"
#include "app_error.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_rtc.h"
#include "nrf_delay.h"
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1   /**< UART RX buffer size. */
#define SAMPLES_IN_BUFFER 1               //Number of SAADC samples in RAM before returning a SAADC event. Do not change this constant for low power SAADC
#define UART_PRINTING_ENABLED							//Enable to see SAADC output on UART. Comment out for low power operation.
void saadc_init(void);
volatile uint8_t state = 1;
const nrf_drv_rtc_t            rtc = NRF_DRV_RTC_INSTANCE(0); /**< Declaring an instance of nrf_drv_rtc for RTC0. */
static nrf_saadc_value_t       m_buffer_pool[2][SAMPLES_IN_BUFFER];
//static uint32_t                m_adc_evt_counter;
 * @brief UART events handler.
void uart_events_handler(app_uart_evt_t * p_event)
 * @brief UART initialization.
void uart_config(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_events_handler,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
                uint32_t err_code;
    if (int_type == NRF_DRV_RTC_INT_COMPARE0)
                                saadc_init();
                                nrf_drv_saadc_sample();
                                LEDS_INVERT(BSP_LED_0_MASK);        //Toggle LED1 to indicate SAADC sampling start
                                err_code = nrf_drv_rtc_cc_set(&rtc,0,2000,true);
                                nrf_drv_rtc_counter_clear(&rtc);
static void lfclk_config(void)
    ret_code_t err_code = nrf_drv_clock_init();
static void rtc_config(void)
    uint32_t err_code;
    //Initialize RTC instance
    err_code = nrf_drv_rtc_init(&rtc, NULL, rtc_handler);
    //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
        ret_code_t err_code;
        LEDS_INVERT(BSP_LED_1_MASK);        //Toggle LED2 to indicate SAADC sampling start
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
#ifdef UART_PRINTING_ENABLED
        //printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
        for (int i = 0; i < SAMPLES_IN_BUFFER; i++)
            printf("%x\r\n", p_event->data.done.p_buffer[i]);
        //m_adc_evt_counter++;
#endif //UART_PRINTING_ENABLED
        nrf_drv_saadc_uninit();
        NRF_SAADC->INTENCLR = (SAADC_INTENCLR_END_Clear << SAADC_INTENCLR_END_Pos);
        NVIC_ClearPendingIRQ(SAADC_IRQn);
     //	nrf_drv_saadc_config_t saadc_config;
    nrf_saadc_channel_config_t channel_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
                //Configure SAADC
    channel_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);
  LEDS_CONFIGURE(LEDS_MASK);     //Configure all leds
  LEDS_OFF(LEDS_MASK);           //Turn off all leds
  //NRF_POWER->DCDCEN = 1;         //Enabling the DCDC converter
    uart_config();                 //Configure UART. UART is used to show the SAADC sampled result.
    printf("\n\rSAADC HAL simple example.\r\n");
                lfclk_config();                //Configure low frequency 32kHz clock
                rtc_config();									 //Configure RTC. The RTC will generate periodic interrupts. Requires 32kHz clock to operate.
    while(1)
        nrf_delay_ms(100);
        //saadc_init();
        //nrf_drv_saadc_sample();
        __WFE();                   //These three commands disable the CPU. CPU will wake up again on any event or interrupt.
        __SEV();
        __WFE();
Does i am making any mistake while doing this?? Please guide me in this regards...
  • Hi Ole,
    First of all thanks for your reply it makes me to understand concept of SAADC and the use of internal and external reference.
    Measuring 1 volt is just for understanding purpose, actually in my application I have to measure the battery voltage from 3.3 volt (below 3.3 volt my device will not work) to 4.1 volt. 3.3 volt indicates 0% and 4.1 indicates 100%.
    for 10 bit resolution if I measure the ADC value for 3.3 volt and 4.1 volt, ideally I should get following value at ADC output 3.3 * (1/6)/0.75 * 1023 ~= 750 and 4.1 * (1/6)/0.75 * 1023 ~= 932
    this is with VDD = 3 volt(hence reference = 3/4 = 0.75). That is the reason I have taken external VDD. But, Here I am getting some strange behaviour. As I goes on increasing resistance, voltage is increasing but, converted value by ADC starts decreasing. That means if I increase input voltage above 3.5 volt ADC values are decreasing. Why This is so? Is it having some connection with voltage reference chosen?
  • Hi Ole,
