Ble uart application wont run when just plugin supply
I have a ble_uart application which is working when I load it on the chip. But it will not automaticly run again if I unplug the supply and just plugin again. When I unplug the supply, then I have to run the application again on Keil.
But if I comment out uart_init(); then the application will automaticly run by plugin the supply.
This behavoir will only appear on the ble_example. The Uart example without SD will run automaticly by plugin even when uart is initialized.
Why the ble_uart application wont run automaticly when I plugin the supply?
Uart_init seems to be the problem. But why it isnt a problem when I run it from Keil?
I cant debug this, because when i start the debugger, then I have to run the program from keil, and then it will always run.
We use a Raytac module. This module has no external LFKC. Does Ble_Uart work without LFKC?
Here my UART initialization
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud19200
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
