I have suspended my Beacon in SLEEP (at .5 uA) until a keypress. Is there an event that can trigger an event if there is a low voltage detection while in SLEEP?
My goal is to wake up if the battery falls < 2.x volts so I can send a special coded advertisement.
If this is not possible, is there a routine that can give me a value so I can change my Minor value with if the voltage falls below a safe value. Then I will send it at intervals.
Where is the spec for this brown-out value ? 3.0v 2.x?
Thanks to all!
J
uint32_t err_code;
//configure button 0 for wakeup
nrf_gpio_cfg_sense_input(BSP_BUTTON_0, GPIO_PIN_CNF_PULL_Pullup, GPIO_PIN_CNF_SENSE_Low);
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
if(p_ble_evt->header.evt_id == BLE_GAP_EVT_TIMEOUT)
sleep_mode_enter();
