how to config TWI in NRF52832
I have a hard time to initial a twi ,I reference the example in the SDK11.0,and I used the board is 10040,I copy the example twi sensor code in my project ,but there is an error when i build it: my code is : const nrf_drv_twi_t m_twi_mma_7660 = NRF_DRV_TWI_INSTANCE(0);
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    ret_code_t err_code;
    static uint8_t m_sample;
    switch(p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if ((p_event->type == NRF_DRV_TWI_EVT_DONE) &&
                (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX))
                if(m_set_mode_done != true)
                    m_set_mode_done  = true;
                    return;
                m_xfer_done = false;
                /* Read 4 bytes from the specified address. */
                err_code = nrf_drv_twi_rx(&m_twi_mma_7660, 0x00, (uint8_t*)&m_sample, sizeof(m_sample));
               // read_data(&m_sample);
              //  m_xfer_done = true;
void IIC_init(void)
		uint32_t err_code;
  const nrf_drv_twi_config_t twi_mma_7660_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOW
    err_code = nrf_drv_twi_init(&m_twi_mma_7660, &twi_mma_7660_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi_mma_7660);
and when i build ,the error is :
Build target 'nrf52832_xxaa_s132'
compiling nrf_drv_twi.c...
..\..\..\..\..\..\components\drivers_nrf\twi_master\nrf_drv_twi.c(38): error:  #35: #error directive: "Wrong configuration."
      #error "Wrong configuration."
..\..\..\..\..\..\components\drivers_nrf\twi_master\nrf_drv_twi.c: 0 warnings, 1 error
compiling iic.c...
".\_build\nrf52832_xxaa_s132.axf" - 1 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:03
And when i double click the error,the cursor is on the file nrf_drv_twi.c :
#if (defined(TWIM_IN_USE) && defined(TWI_IN_USE))
    // TWIM and TWI combined
    #define CODE_FOR_TWIM(code) if (p_instance->use_easy_dma) { code }
    #define CODE_FOR_TWI(code)  else { code }
#elif (defined(TWIM_IN_USE) && !defined(TWI_IN_USE))
    // TWIM only
    #define CODE_FOR_TWIM(code) { code }
#elif (!defined(TWIM_IN_USE) && defined(TWI_IN_USE))
    // TWI only
    #define CODE_FOR_TWI(code)  { code }
#else
the wrong configuration.
