NFC code not working
I'm trying to get NFC working on a PCA10040 dev board. Using the nfc/record_url hex file it works fine, so the hardware is obviously ok.
However, when I use the exact same code as in the record_url example from my software, it doesn't do anything. All functions execute without errors, but then log_uart_printf gets called with:
[NFC_HAL]: initialize
[NFC_HAL]: start
// ------------- put NFC device near
[NFC_HAL]: fielddetected
[NFC_HAL]: reinitialize
Also, will the NFC code ever be distributed as something that's not a binary blob? I'm using a language interpreter (Espruino), and it expects functions to be compiled without hardware floating point (the call style is different). Currently the only way I can use NFC is to recompile with VFP, which means I'm then unable to pass floating point values into any functions!
