UART0 Interrupt stops after some time
Hi , I am using S120 ble_app_multilink_central example. I have configured UART0 in interrupt mode. I send some command and expect some response. It work very well in starting but after some time it stops responding. Although UART0 is functional but its interrupt stops responding.
I am sending command "HNDSK\r\n" and expect response "OK Done\r\n". My code is as below-
void UART0_IRQHandler(void)
  if(NRF_UART0->EVENTS_RXDRDY == 1)
		uart_buffer[uart_buf_head] =  (uint8_t)NRF_UART0->RXD;
		uart_buf_head++;
		NRF_UART0->EVENTS_RXDRDY = 0;
		if(uart_buffer[uart_buf_head-1]==0x0a && uart_buffer[uart_buf_head-2]==0x0d){
			if(strstr((const char*)uart_buffer, "HNDSK\r\n")) //Handshake
					simple_uart_putstring((const uint8_t*)"OK Done\r\n");
			uart_buf_head=0;
			ClearBuffer(uart_buffer,20);
			uart_buf_head=0;
		else if(uart_buf_head>10){
			uart_buf_head=0;
int main(void){
	app_trace_init();
	NRF_UART0->INTENSET = UART_INTENSET_RXDRDY_Enabled << UART_INTENSET_RXDRDY_Pos;
    NVIC_SetPriority(UART0_IRQn, 1);//APP_IRQ_PRIORITY_LOW==3
    NVIC_EnableIRQ(UART0_IRQn);
    ble_stack_init();
    client_handling_init();
    device_manager_init();
    scan_start();
	start_timer();//i ms interrupt
    for (;;)
Please help.
  • @PK: Could you try to move the simple_uart_putstring((const uint8_t*)"OK Done\r\n"); out of the interrupt handler and instead set up a flag in the main loop and print it our when the flag is set ? I m suspecting maybe you spend too much time in the interrupt handler that can cause an issue.
  • @Hung Bui. Thank you for your help. Yes i did the same at first but didnt work. Because interrupt didnt triggered so could not set the flag.
    But I solved the problem by making a small change. I replaced the following code-
    uart_buf_head++;
    By this code-
        uart_buf_head++;
    Now my interrupt is working perfectly and it does not stuck.
