How to test DTM with nRFgo Studio?
I read a document, "Setting up production test using DTM", "nAN-034 Application Note v1.0". And, Figure 3 shows how to setup test environment. But, I cannot find which S/W need to be downloaded to nRF51DK and tester PC. My question is written red color in below image.
image description
  • Q1. Is it correct to download direct_test_mode example on DUT?
  • Q2.What hex file should be downloaded to nRF DK?
  • Q3. What S/W and how to operate the S/W?
Best Regards.
    Q1: Yes the DUT should be flashed with the DTM example.
    Q2: The DK should also be flashed with the DTM example. The roles of each device is decided by the upper tester, which controls the devices over UART.
    Q3: The tester should run the python script from the zip that is attached with nAN34. The documentation for the script and DTM library is found in the readme file in the .zip.
    Øyvind
  • Thank you for your andwer.
    If I use setup as "Figure 2 Setup with PCB module with SMA connector as Lower Tester", and run nRFgo studio on 'computer', what is correct choose for com port for Direct Test Mode?
    Please refer below image. What is corrct choose, 1(for DUT) or 2(for nRF DK)?
    Best regards.
    Jake
    To be honest I've never done this in nRFGo studio, only used the script. I think the trick in nRFGo studio is to have two instances running, and program the DUT in one and the lower tester in the other.
    Assuming COM 11 is your DUT and COM 9 is the lower tester
    To test DUT RX
    • Program COM 9 to transmit
    • Program COM 11 to receive
    • Verify that you are getting the right amount of packets
    To test DUT TX
    • Program COM 11 to transmit
    • Program COM 9 to receive
    For more flexibility you will probably want to set up a script to do this for you, I recommend looking into the python dtm library.
  • Thank you for your information. Very helpful.
