what does ff command do
I'm new to nrf8001 I'm trying to understand an existing example. in this example after sending set up commands generated by nrfgo studio , program sends 9 byte of 0xff command (invalid aci command) , waits for 20 ms and then send 4 byte of that again. why is this happening!?
void setup (void) {
  int m,j;
  unsigned char temp[10],k;
    for(m=0;m<NB_SETUP_MESSAGES;m++) 	{
	      REQN = 0;
            while (RDYN == 1);
	      k=setup_line[m][0];
            spi(k);
            for (j=1;j<=k;j++)
	            spi(setup_line[m][j]);
            REQN=1;
            while(RDYN==0);
            delay_ms(20); 	}
      REQN=0;
      while(RDYN==1);
      spi(ACI_CMD_INVALID);
      REQN=1;
      while(RDYN==0);
      delay_ms(20);
      REQN=0;
      while(RDYN==1);
switch(SPDR)				//SPDR = spi return value
case 1:
      putsf("Device started in TEST mode. \n");
case 2:
putsf("Device started in SETUP mode. \n");
case 3:
putsf("Device started in STANDBY mode. \n");
            putsf("Something goes WRONG!!! \n");
            break; 	};
sprintf(temp,"Number of errors = %d \n",SPDR);
      puts(temp);
sprintf(temp,"Number of dataCommand buffers = %d \n",SPDR);
      puts(temp);
      REQN = 1;
      delay_ms(60);
      while (RDYN == 0); }
here is my bluetooth set up code. the ACI_CMD_INVALID contains 0xff value. I don't understand the need for this invalid opcode
