I am trying to probe sysclk signal on one of the unused GPIO pins on a nRF52 board. I modified the ble_app_template example provided in SDK 11.0.0 and added a sysclk function to see the sysclk signal on P0.11. The project builds and loads with no errors, but when I probe the GPIO pin with a digital scope, I do not see any signals showing up. What could be the problem? Here is the function I added, which I call after ble_stack_init() :
static void sysclk_init( void ) {
uint32_t running;
nrf_gpio_cfg_output( 11 );
// Start high frequency clock with SoftDevice
APP_ERROR_CHECK(sd_clock_hfclk_request());
APP_ERROR_CHECK(sd_clock_hfclk_is_running(&running));
//Wait for clock to start
while(!running) {
// Configure GPIOTE to toggle pin P0.11
NRF_GPIOTE->CONFIG[0] = GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos |
GPIOTE_CONFIG_POLARITY_Toggle << GPIOTE_CONFIG_POLARITY_Pos |
11 << GPIOTE_CONFIG_PSEL_Pos |
GPIOTE_CONFIG_OUTINIT_Low << GPIOTE_CONFIG_OUTINIT_Pos;
// Set up timer
NRF_TIMER1->PRESCALER = 0;
NRF_TIMER1->CC[0] = 16;
NRF_TIMER1->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
NRF_TIMER1->TASKS_START = 1;
// Set up PPI to connect the timer compare event with the GPIOTE toggle task
NRF_PPI->CH[0].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[0];
NRF_PPI->CH[0].TEP = (uint32_t) &NRF_GPIOTE->TASKS_OUT[0];
NRF_PPI->CHENSET = PPI_CHENSET_CH0_Enabled << PPI_CHENSET_CH0_Pos;
