I am working with the GPIOTE library to get a GPIOTE_IRQ from a peripheral.
I have several questions regarding the library and how IRQ works.
1.How do I clear the event for the gpiote input. I know that void GPIOTE_IRQHandler(void)
does the clearing for you but I am wondering if there is a way I can clear it when I need to.
This needs to happen because I need to do something while I am in my GPIOTE_IRQHandler when there is another GPIOTE_IRQ signal coming from the peripheral.
I know that I can use nrf_drv_gpiote_in_is_set(GPIOPE_IRQ_Pin) to check if the pin is set.
However, the only function that actually clears the event needs an event input
__STATIC_INLINE void nrf_gpiote_event_clear ( nrf_gpiote_events_t event )
So I though of using
uint32_t nrf_drv_gpiote_in_event_addr_get ( nrf_drv_gpiote_pin_t pin )
and manually subtracting NRF_GPIOTE to get the event and use
Is there a better way of clearing the event?
2 Also, I was wondering about the behavior of the IRQ when I manually clear it.
Will clearing the event cause the void GPIOTE_IRQHandler(void) not be called or will it be called anyway.
Thank you, John Lee
