nRF5 IoT SDK v0.9.0 TCP Server Example - Connection refused
Need some help on the tcp server example in the IoT SDK.
All steps working but the python script gets Connection refused.
bash# ifconfig bt0
bt0       Link encap:UNSPEC  HWaddr B8-27-EB-FF-FE-1A-A7-41-00-00-00-00-00-00-00-00
      inet6 addr: fe80::ba27:ebff:fe1a:a741/64 Scope:Link
      inet6 addr: 2001::ba27:ebff:fe1a:a741/64 Scope:Global
      inet6 addr: 2004::ba27:ebff:fe1a:a741/64 Scope:Global
      UP POINTOPOINT RUNNING MULTICAST  MTU:1280  Metric:1
      RX packets:8 errors:0 dropped:0 overruns:0 frame:0
      TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:0
      RX bytes:286 (286.0 B)  TX bytes:1893 (1.8 KB)
bash# ping6 2004::ba27:ebff:fe1a:a741
PING 2004::ba27:ebff:fe1a:a741(2004::ba27:ebff:fe1a:a741) 56 data bytes
64 bytes from 2004::ba27:ebff:fe1a:a741: icmp_seq=1 ttl=64 time=0.170 ms
64 bytes from 2004::ba27:ebff:fe1a:a741: icmp_seq=2 ttl=64 time=0.166 ms
64 bytes from 2004::ba27:ebff:fe1a:a741: icmp_seq=3 ttl=64 time=0.168 ms
^C
--- 2004::ba27:ebff:fe1a:a741 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.166/0.168/0.170/0.001 ms
bash# python tcp_c2
  File "tcp_c2", line 9, in <module>
    sock.connect((SERVER_ADDR, SERVER_PORT))
  File "/usr/lib/python2.7/socket.py", line 228, in meth
    return getattr(self._sock,name)(*args)
socket.error: [Errno 111] Connection refused
bash# cat tcp_c2
import socket
import struct
-#This example assumes the server BD address to be 00:AA:BB:CC:DD:EE and the used global prefix to be 2004::/64.
-#Therefore the global IPv6 address of the server will be 2004::02AA:BBFF:FECC:DDEE.
SERVER_ADDR = '2004::ba27:ebff:fe1a:a741'
SERVER_PORT = 9000
sequence_number = 1
sock = socket.socket(socket.AF_INET6, socket.SOCK_STREAM)
while sequence_number < 101 :
    data = struct.pack("!I", sequence_number)
    data +=  'Ping'
    sock.sendto(data, (SERVER_ADDR, SERVER_PORT, 0, 0))
    recv_data = sock.recvfrom(8)
    print recv_data
    rx_sequence_number = struct.unpack("!I", recv_data[0][:4])[0]
    if sequence_number is not rx_sequence_number:
        print "Sequence number mismatch!"
    sequence_number+= 1
sock.close()
Output from device:
[APPL]: Port Setup.
[APPL]: Init done.
[APPL]: Physical layer in connectable mode.
[APPL]: Physical layer: connected.
[APPL]: IPv6 interface up.
  • Hi. The IP address fe80::ba27:ebff:fe1a:a741 is the address of the bt0 interface on your computer. You need to connect to the IP address of the nRF52 kit. As written in the Python example script:
    00:AA:BB:CC:DD:EE represents the address of the nRF52 kit. And you can work out the IP address by using the above "formula".
