nrf52 consumes quite lot of power
Hi.
I'm little worried about our bt sensor power consumption.
We are using twi/i2c to communicate with sensors periodically. We are using app timer to trigger these events and with some sensors we use hw interrupt.
Anyho I observed that there's 4.3-5mA consumption going on pretty much no matter I do. I even made a build, where there's nothing else done than waiting for event:
void main (void) {
     for(;;) {
          // Enter System ON sleep mode
          __WFE();
          // Make sure any pending events are cleared
          __SEV();
          __WFE();
Still the power consumption is quite large. I don't have uart tracing on in Makefile.
  #flags common to all targets
   CFLAGS  = -DNRF52
   CFLAGS += -DSOFTDEVICE_PRESENT
   CFLAGS += -DBOARD_PCA10040
   CFLAGS += -DNRF52_PAN_12
   CFLAGS += -DNRF52_PAN_15
   CFLAGS += -DNRF52_PAN_58
   CFLAGS += -DNRF52_PAN_55
   CFLAGS += -DNRF52_PAN_54
   CFLAGS += -DNRF52_PAN_31
   CFLAGS += -DNRF52_PAN_30
   CFLAGS += -DNRF52_PAN_51
   CFLAGS += -DNRF52_PAN_36
   CFLAGS += -DNRF52_PAN_53
   #CFLAGS += -DNRF_LOG_USES_UART=1
   CFLAGS += -DS132
   CFLAGS += -DCONFIG_GPIO_AS_PINRESET
   CFLAGS += -DBLE_STACK_SUPPORT_REQD
   CFLAGS += -DSWI_DISABLE0
   CFLAGS += -DNRF52_PAN_20
   CFLAGS += -DNRF52_PAN_64
   CFLAGS += -DNRF52_PAN_62
   CFLAGS += -DNRF52_PAN_63
   CFLAGS += -mcpu=cortex-m4
   CFLAGS += -mthumb -mabi=aapcs --std=gnu99
   CFLAGS += -Wall -O3 -g3
   CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
   # keep every function in separate section. This will allow linker to dump unused functions
   CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
   CFLAGS += -fno-builtin --short-enums
   LDFLAGS += -Xlinker -Map=$(LISTING_DIRECTORY)/$(OUTPUT_FILENAME).map
   LDFLAGS += -mthumb -mabi=aapcs -L $(TEMPLATE_PATH) -T$(LINKER_SCRIPT)
   LDFLAGS += -mcpu=cortex-m4
   LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
   # let linker to dump unused sections
   LDFLAGS += -Wl,--gc-sections
   # use newlib in nano version
   LDFLAGS += --specs=nano.specs -lc -lnosys
   # Assembler flags
   ASMFLAGS += -x assembler-with-cpp
   ASMFLAGS += -DNRF52
   ASMFLAGS += -DSOFTDEVICE_PRESENT
   ASMFLAGS += -DBOARD_PCA10040
   ASMFLAGS += -DNRF52_PAN_12
   ASMFLAGS += -DNRF52_PAN_15
   ASMFLAGS += -DNRF52_PAN_58
   ASMFLAGS += -DNRF52_PAN_55
   ASMFLAGS += -DNRF52_PAN_54
   ASMFLAGS += -DNRF52_PAN_31
   ASMFLAGS += -DNRF52_PAN_30
   ASMFLAGS += -DNRF52_PAN_51
   ASMFLAGS += -DNRF52_PAN_36
   ASMFLAGS += -DNRF52_PAN_53
   ASMFLAGS += -DNRF_LOG_USES_UART=1
   ASMFLAGS += -DS132
   ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
   ASMFLAGS += -DBLE_STACK_SUPPORT_REQD
   ASMFLAGS += -DSWI_DISABLE0
   ASMFLAGS += -DNRF52_PAN_20
   ASMFLAGS += -DNRF52_PAN_64
   ASMFLAGS += -DNRF52_PAN_62
   ASMFLAGS += -DNRF52_PAN_63
With this setup I can measure (from USB) 4.39mA consumption.
Ideas?
Build made with gcc, no peripherals attached to board (altough there has been before if that matters), I've run also the "nrfjprog -f nrf52 -p" to disable debug mode.
