why nrf51422 have problem with timer?
without timer it work fine but when i use timer it goes here. image description
my timer code is this
#define APP_TIMER_PRESCALER                  0                                          /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS                 6                                          /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE              4                                          /**< Size of timer operation queues. */
#define TIMER_PRESCALERS  6U       /**< Prescaler setting for timer. */
static app_timer_id_t                        m_battery_timer_id;                        /**< Battery timer. */
#define BATTERY_LEVEL_MEAS_INTERVAL          APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                    81                                         /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                    100                                        /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT              1                                          /**< Increment between each simulated battery level measurement. */
static void battery_level_meas_timeout_handler(void * p_context)
    static int i = 0 ;
		i++;
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    uint32_t err_code;
    // Initialize timer module.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
		// Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
static void application_timers_start(void)
    uint32_t err_code;
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
i found out that when interupt is trigered its going to that picture line
