I have a nordic chip (nrf2832) and I am trying to use it as a LWM2M client and register it to a LWM2M Server. I want to achieve this: developer.nordicsemi.com/.../LWM2M_client.svg
I have already done the steps described in developer.nordicsemi.com/.../a00089.html
root@raspberrypi:/home/pi# ping6 -I bt0 ff02::1 PING ff02::1(ff02::1) from fe80::ba27:ebff:fed7:2a95 bt0: 56 data bytes 64 bytes from fe80::ba27:ebff:fed7:2a95: icmp_seq=1 ttl=64 time=0.162 ms 64 bytes from fe80::206:99ff:feea:bb16: icmp_seq=1 ttl=64 time=186 ms (DUP!)
I am now stuck in the steps described in developer.nordicsemi.com/.../a00082.html
According to the steps, I should give these commands:
ifconfig bt0 add 2001:db8::1/64 ifconfig bt0 add 2001:db8::2/64
It also says that the commands assume that the bt0 interface is already up running.
My understanding is that 2001:db8::1/64 is the IPV6 address of bootstrap server and 2001:db8::2 is the IPv& address of management server, right? However, bt0 interface is on the raspberry pi and NOT the server running Leshan server, right?
So where exactly do I run 'ifconfig bt0 add 2001:db8::1/64' and 'ifconfig bt0 add 2001:db8::2/64'? Raspberry Pi or ubuntu machine?
