Anyone to tell me where can i get the CDB file for nRF24LE01? I've downloaded the SDK and the nRF go Studio, but i still cannot find the CDB file.. Please help me to find this out.. Thanks..
This CDB file should be installed with the SDK. Which SDK did you download? Remember that you must use the nRFgo SDK for the nRF24LE1, not the nRF51 SDK. Also, you should make sure that you install the SDK after having installed Keil.
I did install using the nRFgo SDK for nRF24LE1. I found the sample codes and precompiled hex for nRF24LE1 and nRF24LU1. I am sure that I installed the nRFgo SDK after I installed keil. Did I miss something? Currently I am manually adding the nRF24LE1 via the device database on Keil and it works very well for me now.. Thanks
Great that you've gotten things working! Unfortunately, I'm not able to replicate the problem you're describing, so I don't really have any further suggestions. Feel free to edit your question and expand a little on what you did, and then accept it as an answer, to help others who may have similar problems and to clear up this question! :)
I found the solution to manually add the device selection menu on Keil. If you already have a nRF24.CDB file (you can get by installing nRFgo SDK, make sure that you installed Keil first), then you don't need to do this :D.
To manually add the device selection, just click on File->Device Database on Keil. Select Generic CPU Data Base if prompted to. You will be brought to the Device Database window. In the Device Database window, find Nordic Semiconductor and manually add the description, Vendor data, and IC type. You can find the description on keil's website. :D. Hope it helps!
