shutdown BLE_peripheral
this is my code: this is BLE_peripheral UART and i added these lines to main(): my soft device is S130 V2 alpha
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
printf("%s",start_string);
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
// Enter main loop.
for (;;)
    int i = 0;
    for(i=0;i<95000000;i++);//delay
    NRF_RADIO->TASKS_DISABLE = 1;
    NRF_RADIO->TASKS_STOP = 1;
	NVIC_DisableIRQ(RTC1_IRQn);
    err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_DEV_TERMINATION_DUE_TO_POWER_OFF);
    NRF_RADIO->POWER = 0;
    sd_ble_gap_rssi_stop(m_conn_handle);
    printf("A");
    sd_ble_gap_adv_stop();
    printf("b");
    power_manage();
it stops advertising but not disconnect from central and I can send or receive data
I want to turn off BLE and turn it on when I want but I don't know how?
  • Hi Ali,
    On the condition that you want to shutdown BLE you can just call sd_softdevice_disable.
    If you want to re enable, then enable the softdevice and ble using the example functions like ble_stack_init
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        // Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT, PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
        // Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    The documentation for each functions can be found in Nordic infocenter.
  • I used that but my device was reset? and it starts automatically
  • Then it means that error_code some where in the function was returned with errors. And the APP_ERROR_CHECK will call the default implementation of app_fault_handler (you can override this function) which will reset the device using NVIC_SystemReset function call. I recommend you to put a breakpoint and see which call returned error.
  • Hi, when i do sd_softdevice_disable the register is not deinit, the BLE is just in standby. I need to fully deinit because i use a soft with DFU and BEACON. and i can't use 2 in same time. I will deinit fully de BEACON for use DFU without problem. For the moment i can use the DFU independently, and use the Beacon independently but i can't use BEACON and after push button switch into DFU mode.
