I wrote a program that uses ESB communication between two nodes. On both sides I use the same ESB configuration and the same ESB init function, the difference is only what the nrf_esb_mode
is being set to (NRF_ESB_MODE_PTX
or NRF_ESB_MODE_PRX
, respectively).
Now if I set my node to be PRX, my event handler is called with NRF_ESB_EVENT_RX_RECEIVED
for each incoming packet, which is good.
But if I set my node to be PTX, and I put a payload into the ESB FIFO by calling nrf_esb_write_payload(...)
[which returns with NRF_SUCCESS
], nothing happens. I see no packets coming in on the other side, and also, my event handler is not called with whatever event (no NRF_ESB_EVENT_TX_SUCCESS
nor NRF_ESB_EVENT_TX_FAILED
) on the TX side.
How can that be?
May that be an issue of changing ESB mode from RX to TX and vice versa, which I do quite often in my code?
(It is not easy to extract my code from the framework I use, so theoretical answers would be preferred.)
Thanks! NewtoM
