ANT DFU-OTA Update Fail
I am trying the ANT-OTA DFU Update using an ANT Stick and the nr51422 pca 10028 board. The ANT Updater shows that the Image Upload is completed. I am uploading the s210 OTA Tester Application. But the application is not being loaded because the ANTWare II isn't detecting the ANT broadcast from the board. Also, the size of the application, when seen from the nrfgo Studio stays the same. I'm using the SDK 10 version.
File_before_OTA.hex : This is the Hex when the experimental_ant_bootloader is loaded on the board.
File_after_OTA.hex :This is the Hex after the ota_tester is loaded on the board via OTA Updater 1.4 (via application bar) .
File_after_BootloaderOTA.hex :This is the Hex after a custom file with boootloader is loaded on the board via OTA Updater 1.4 (via bootloader bar) .
nrf51422_xxac.hex: Application to be uploaded via OTA Updater.
Thank You.
