How could I program the BMD-300 with a nRF52 Preview Development Kit?
Hello Everyone,
I want to program the BMD-300 with the nRF52 Preview Development Kit. I have connected:
BMD-300 -> nRF52-DK
SWDIO -> SH_SWDIO (pin #4) on P20
SWDCLK -> SH_SWDCLK (pin #5) on P20
VDD -> SH_VTG (pin #3) on P20
GND -> SH_GND_DETECT (pin #8) on P20
The BMD-300 is powered by a generator (3V).
image description
JTAG connector: www.tag-connect.com/.../TC2050-IDC-NL Datasheet.pdf
Now, when I use nRFgo Studio, it doesn’t work: Following Text is written:
Latest motherboard firmware: 7000 Boards connected: No boards connected.
When I use µvision (Keil), it doesn’t work too. Following Text is written:
JLink – Cortex-M Error No Cortex-M SW Device Found
µVision Error: Flash Download faild – Target DLL has been cancelled
Build Output:
JLink info:
DLL: V5.12f, compiled May 17 2016 16:03:35
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 15 2016 18:03:17
Hardware: V1.00
S/N : 682984698
JLink Info: Found SWD-DP with ID 0x2BA01477
JLink Error: Communication timed out: Requested 20 bytes, received 0 bytes ! Could not read hardware status!
Error: Flash Download failed - Target DLL has been cancelled
If someone knows, what I have done wrong, I would be happy, if he/she could help me.
Thank you
  • Also make sure to edit your boards def file. The BMD-300 uses a resonator not an xtal. I had the same problem with my code not working and this fixed it.
    Original code toward the bottom of the file: // Low frequency clock source to be used by the SoftDevice #define NRF_CLOCK_LFCLKSRC {.source = NRF_CLOCK_LF_SRC_XTAL,
    .rc_ctiv = 0,
    .rc_temp_ctiv = 0,
    .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM} Change this to: // Low frequency clock source to be used by the SoftDevice #define NRF_CLOCK_LFCLKSRC {.source = NRF_CLOCK_LF_SRC_RC,
    .rc_ctiv = 16,
    .rc_temp_ctiv = 4,
    .xtal_accuracy = 0}\ accuracy ignored when using RC
    .rc_ctiv = 0,
    .rc_temp_ctiv = 0,
    .rc_ctiv = 16,
    .rc_temp_ctiv = 4,
