there is an error on softdevice on src\ll_adv.c on line of 659 . what is the reason?
this is my adv init
#define DEVICE_NAME                          "navid"                               /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                    "NordicSemiconductor"                      /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                     160                                        /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS           0                                        /**< The advertising timeout in units of seconds. */
#define APP_TIMER_PRESCALER                  0                                         /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS                 4                                         /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE              12                                          /**< Size of timer operation queues. */
#define RR_INTERVAL_INTERVAL                 APP_TIMER_TICKS(300, APP_TIMER_PRESCALER)  /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL                      100                                        /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                      500                                        /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT                1                                          /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL     APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL                    MSEC_TO_UNITS(500, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL                    MSEC_TO_UNITS(1000, UNIT_1_25_MS)          /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                        0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                     MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY        APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT         3                                          /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_TIMEOUT                    5                                         /**< Timeout for Pairing Request or Security Request (in seconds). */
#define SEC_PARAM_BOND                       1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                       0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES            BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                        0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE               7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE               16                                         /**< Maximum encryption key size. */
#define DEAD_BEEF                            0xDEADBEEF                                 /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    ble_uuid_t adv_uuids[] =
				{BLE_UUID_OUR_SERVICE, BLE_UUID_TYPE_BLE} // i deleted all other services and let my service be only
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance      = true;
    advdata.flags.size              = sizeof(flags);
    advdata.flags.p_data            = &flags;
    advdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    advdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_set(&advdata,NULL);
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_IND;
    m_adv_params.p_peer_addr = NULL;                           // Undirected advertisement.
    m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval    = APP_ADV_INTERVAL;
    m_adv_params.timeout     = APP_ADV_TIMEOUT_IN_SECONDS;
