Only 1 to 1 bluetooth matching about nrf51822
Hello. I want only 1 to 1 bluetooth matching about nrf51822.
I want only 1EA central with 1EA peripheral matching.
I set as below.
1EA - Bluetooth Central - UUID 0x08
1EA - Bluetooth Peripheral - UUID 0x08
1EA - Bluetooth Peripheral - UUID 0x11
I expectation is to be connect UUID 0x08 central with 0x08 peripheral.
So, UUID 0x11 is disconnect.
but, The test results were also connected with the uuid 0x11 peripheral uuid 0x08 central.
I think, need to other part except uuid. please confirm it.
  • You need to clarify your question. Let me try to re-phrase it.
    You need to connect 1 central to one peripheral, the grouping of peripheral and central is based on a UUID (For example, 0x08) , a peripheral with UUID 0x11 is not allowed to connect to a central with UUID 0x08.
    Is my understanding correct ?
  • you are right. it is possible?
  • The central decides what device it wants to connect to.
    It normally uses the content of the advertisment to do this, for example the UUID.
    It can search for a specific UUID, and then send a connect request to the device that sent an advertisment with this UUID.
    This is done in the ble_app_hrc_c example in SDK. Have a look at how the BLE_GAP_EVT_ADV_REPORT in on_ble_evt() is handled. When it receives an advertisment with the heart rate service UUID it will try to connect to that device.
  • thank you for your comment. I will reconfirm it.
