Can't set up timer in couner mode with ppi
Hi. I am trying to set up timer in counter mode to count up signals from gpio through the ppi module, but it's not working. In main cycle I am testing the timer using led :) . Code:
#define frenq_counter_pin 13
#define test_counter_pin 18
#define GPIOTE_CHANNEL_NUMBER 0;
const nrf_drv_timer_t timer1 = NRF_DRV_TIMER_INSTANCE(1);
nrf_ppi_channel_t ppi_channel1;
void timer_void_handler(nrf_timer_event_t event_type, void * p_context){}
void pin_event_void_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){}
void counter_init(void) {
	nrf_drv_timer_config_t conf;
	conf.mode = TIMER_MODE_MODE_Counter;
    conf.bit_width = TIMER_BITMODE_BITMODE_16Bit;
    APP_ERROR_CHECK(
		nrf_drv_timer_init(
            &timer1,
            &conf,
            timer_void_handler
nrf_drv_timer_enable(&timer1);
void gpiote_init(){
    APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
    nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
    config.pull = NRF_GPIO_PIN_PULLUP;
    nrf_drv_gpiote_in_init(frenq_counter_pin, &config, pin_event_void_handler);
    nrf_drv_gpiote_in_event_enable(frenq_counter_pin, true);
    nrf_gpio_cfg_output(test_counter_pin);
    nrf_gpio_pin_set(test_counter_pin);
void ppi_init(){
    uint32_t err_code = NRF_SUCCESS;
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel1);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel1,
                                      nrf_drv_gpiote_in_event_addr_get(frenq_counter_pin),
                                      nrf_drv_timer_task_address_get(&timer1, NRF_TIMER_TASK_COUNT));
    nrf_drv_ppi_channel_enable(ppi_channel1);
int main(void) {
    counter_init();
    gpiote_init();
    ppi_init();
    for (;;) {
        if (((int)nrf_drv_timer_capture(&timer1,NRF_TIMER_CC_CHANNEL0)) >= 10) {
            nrf_gpio_pin_toggle(test_counter_pin);
            NRF_TIMER1->CC[0] = 0;
Thank you for help!
  • I haven't tried it using drivers but here is the post that did this without using drivers. Note that TIMER1 and PPI next to it used to stop the TIMER2 after 1 second. In your case you just need to configure GPIOTE->PPI->TIMER2 in counter mode. @adriand has updated the thread with his code.
  • Thank's for link. I solved that problem using drivers:
    Initialisation:
    	nrf_drv_timer_t timer1 = NRF_DRV_TIMER_INSTANCE(2);
    	uint32_t capture_frenq(){
    		uint32_t frenq_ = nrf_drv_timer_capture(
    					&timer1,
    		timer1.p_reg->TASKS_CLEAR = 1;
    		timer1.p_reg->TASKS_START = 1;
    		return frenq_;
    	// Void handler
    	//Counter only
    		   conf.p_context = &timer1;
    		APP_ERROR_CHECK(
    				   nrf_drv_timer_init(
    						   &timer1,
    						   &conf,
    						   timer_void_handler
    	void gpiote_init(nrf_drv_gpiote_pin_t frenq_counter_pin){
    		nrf_drv_gpiote_init();
    		nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    	void ppi_init(nrf_drv_gpiote_pin_t frenq_counter_pin){
    	void speedometer_init(nrf_drv_gpiote_pin_t pin){
    		counter_init();
    		gpiote_init(pin);
    		ppi_init(pin);
    Application timer for frequency capturing:
    void timers_init(void)
    	uint32_t err_code;
    	APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    	err_code = app_timer_create(&speed_timer_id,
    								APP_TIMER_MODE_REPEATED,
    								speed_meas_handler);
    void speed_meas_handler(void * p_context){
    	freq_ = capture_freq();
  • Thank you for sharing your solution!
