Known issues and feature requests of nRF Connect
On nRF Connect v1.0 production only
GENERAL RULE TO KEEP THIS PAGE READABLE
  • This is ONLY for already confirmed bugs which are discussed in another threads. Please do not discuss here in the comments to try to figure out that the issue you are facing is a bug or not. Please create a separate question. You can add a link to the question here to inform, but we will remove the comment after it's acknowledged.
  • You can add a feature requests by commenting on the Answer for feature request bellow. We will update the answer for feature requests and remove the comment after it's acknowledged.
  • Do not edit the answer. If I forgot an already discussed and confirmed bug, then please add the link to the issue in comment, I will then update the answer with your link.
  • If it is a minor edit, then I will select "minor edit" option in my edits. But if i am adding new issue, then I will not select "minor edit" and hence will send notifications to one following. Click "Follow" the case to get notification.
