Hello everyone,
I was looking for whether i could change the NRF52832 s - I want range up to 5 meters- the range or not.
Thanks for your helps.
Hello everyone,
By lowering the TX power you will get lower range, so instead of +4 dBm you could lower it to for example +0 dBm (you need to tune this for your application) to get less range.
Øyvind
Is TX power mean VCC? Most probably not but how and where could i change its gain?
Thanks a lot.
TX power is the Radio Frequency (RF) signal strength at the output. You can set this by using the ant function sd_ant_channel_radio_tx_power_set.
Øyvind
