Use NRF_CLOCK_LFCLKSRC_RC_250_PPM_250MS_CALIBRATION
How could I rebuild the code for an NRF_CLOCK_LFCLKSRC_RC_250_PPM_250MS_CALIBRATION?
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
// Low frequency clock source to be used by the SoftDevice
#define NRF_CLOCK_LFCLKSRC      {.source        = NRF_CLOCK_LF_SRC_XTAL,            \
                             .rc_ctiv       = 0,                                \
                             .rc_temp_ctiv  = 0,                                \
                             .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM}
/**@defgroup NRF_CLOCK_LF_XTAL_ACCURACY Clock accuracy * @{ */
#define NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM (0) /* Default */
#define NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM (1)
#define NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM (2)
#define NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM (3)
#define NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM  (4)
#define NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM  (5)
#define NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM  (6)
#define NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM  (7)
/**@defgroup NRF_CLOCK_LF_SRC Possible lfclk oscillator sources * @{ */
#define NRF_CLOCK_LF_SRC_RC      (0)                        /**< LFCLK RC oscillator. */
#define NRF_CLOCK_LF_SRC_XTAL    (1)                        /**< LFCLK crystal oscillator. */
#define NRF_CLOCK_LF_SRC_SYNTH   (2)                        /**< LFCLK Synthesized from HFCLK. */
/** @addtogroup NRF_SDM_TYPES Types
/**@brief Type representing lfclk oscillator source. */
typedef struct
  uint8_t source;        /**< LF oscillator clock source, see @ref NRF_CLOCK_LF_SRC. */
  uint8_t rc_ctiv;      /**< Only for NRF_CLOCK_LF_SRC_RC: Calibration timer interval in 1/4 second
                              units (nRF51: 1-64, nRF52: 1-32).
                              @note To avoid excessive clock drift, 0.5 degrees Celsius is the
                                    maximum temperature change allowed in one calibration timer
                                    interval. The interval should be selected to ensure this.
                              @note Must be 0 if source is not NRF_CLOCK_LF_SRC_RC.  */
  uint8_t rc_temp_ctiv; /**<  Only for NRF_CLOCK_LF_SRC_RC: How often (in number of calibration
                              intervals) the RC oscillator shall be calibrated if the temperature
                              hasn't changed.
                                  0: Always calibrate even if the temperature hasn't changed.
                                  1: Only calibrate if the temperature has changed (nRF51 only).
                                  2-33: Check the temperature and only calibrate if it has changed,
                                        however calibration will take place every rc_temp_ctiv
                                        intervals in any case.
                              @note For nRF52, the application must ensure calibration at least once
                                    every 8 seconds to ensure +/-250ppm clock stability. The
                                    recommended configuration for NRF_CLOCK_LF_SRC_RC on nRF52 is
                                    rc_ctiv=16 and rc_temp_ctiv=2. This will ensure calibration at
                                    least once every 8 seconds and for temperature changes of 0.5
                                    degrees Celsius every 4 seconds. See the Product Specification
                                    for the nRF52 device being used for more information.*/
  uint8_t xtal_accuracy; /**< External crystal clock accuracy used in the LL to compute timing windows.
                              @note For the NRF_CLOCK_LF_SRC_RC clock source this parameter is ignored. */
} nrf_clock_lf_cfg_t;
/**@brief Fault Handler type.
 * When certain unrecoverable errors occur within the application or SoftDevice the fault handler will be called back.
 * The protocol stack will be in an undefined state when this happens and the only way to recover will be to
 * perform a reset, using e.g. CMSIS NVIC_SystemReset().
 * @note This callback is executed in HardFault context, thus SVC functions cannot be called from the fault callback.
 * @param[in] id Fault identifier. See @ref NRF_FAULT_IDS.
 * @param[in] pc The program counter of the instruction that triggered the fault.
 * @param[in] info Optional additional information regarding the fault. Refer to each Fault identifier for details.
typedef void (*nrf_fault_handler_t)(uint32_t id, uint32_t pc, uint32_t info);
Normally, I would write:
     uint32_t err_code;
    //SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL); XXX
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_250MS_CALIBRATION, NULL);
But this does not work.
Thanks for help!
