how to use fstorage on nRF51 with SDK10
ba_nRF51_spd.zipHi, I use nRF51422, SDK10, SD310 and fstorage fun beacuse I need save 10 uint32_t len datas to flash.
I did that....:
the callback fun
static void fs_callback(uint8_t           op_code,
                            uint32_t          result,
                            uint32_t  const * p_data,
                            fs_length_t       length)
   switch(op_code){
		 case FS_OP_NONE:
     case FS_OP_STORE:
     case FS_OP_ERASE:
initial fs_init in main()
    // Initialize S310 SoftDevice
    ble_ant_stack_init();
    // Initialize Bluetooth stack parameters.
    gap_params_init();
    advertising_init();
    services_init();
    conn_params_init();
    // Initialize ANT CSC TX channel.
    ant_SpeedTx_init();
    application_timers_start();
	  ret_code_t retval = fs_init();
    if (retval != NRF_SUCCESS)
        // fs_init() failed, propagate the error.
        return retval;
		flash_word_read(fs_config.p_start_addr, &data);
		m_ant_bsc.page_1.operating_time =data;
		if( m_ant_bsc.page_1.operating_time >= 0xFFFFFFFF){
			  m_ant_bsc.page_1.operating_time=0;
}//main
    void flash_word_read(uint32_t* address, uint32_t* value)
    *value = *address;
and I read the data back always is 0xFFFFFFFF.
I put the fs_erase and fs_store in other application_time when the 3min I need save the data in flash.
retval =fs_erase(&fs_config, fs_config.p_start_addr,1);
    //return retval;
	m_ant_bsc.page_1.operating_time=6789;
  m_csc_obj.ant_op_time = m_ant_bsc.page_1.operating_time;
  retval = fs_store(&fs_config, fs_config.p_start_addr, &m_csc_obj.ant_op_time, 1);
    //return retval;
I modify the sd310 stack init make sure the sys_evt_dispatch does work.
static void ble_ant_stack_init(void)
//#ifdef BONDING_ENABLE
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
//#endif // BONDING_ENABLE
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    fs_sys_event_handler(sys_evt);
Is there any thing I did wrong because when MCU power on I read the data once always 0xFFFFFFFF.
Thanks.
