How to stop watch dog
hi, I'am working in a project. I start a watch dog in that project,but I need to stop the watch dog something.And I don't know how to stop, can anybody help me.
  • you cannot stop the watchdog once it is started. It can configured to pause while CPU is sleeping or debugger halted the CPU (in the CONFIG register) but in normal mode you cannot stop it.
  • how should I feed the watch dog in bootloarder. I had try to feed the dog like that,but it couldn't work fine after dfu.
    /**@brief Function for initialization of time handle.
    //timer calender
    static void timer_index_feed_wd( void *p_context )
       //fed the dog
    	 NRF_WDT->RR[0] = WDT_RR_RR_Reload;
    /**@brief Function for initializing the timer handler module (app_timer).
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler.
        APP_TIMER_APPSH_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, true);
    	  uint32_t err_code;
    	  err_code = app_timer_create( &FEED_WD_TIMER, APP_TIMER_MODE_REPEATED, timer_index_feed_wd );
    main()
    if (dfu_start || (!bootloader_app_is_valid(DFU_BANK_0_REGION_START)))
    				DisplayDFU( );
    				//stop timer
    			  err_code = app_timer_start(FEED_WD_TIMER, FEED_WATCH_DOG_PERIOD, NULL);
            // Initiate an update of the firmware.
            err_code = bootloader_dfu_start();
        if (bootloader_app_is_valid(DFU_BANK_0_REGION_START) && !bootloader_dfu_sd_in_progress())
            // Select a bank region to use as application region.
            // @note: Only applications running from DFU_BANK_0_REGION_START is supported.
    				err_code = app_timer_stop( FEED_WD_TIMER );
            bootloader_app_start(DFU_BANK_0_REGION_START);
  • if you feed the watchdog in the bootloader then after the dfu a reset will be generated and will also reset the watchdog registers, where you feed the watchdog depends on what you are trying to achieve?
  • It didn't reset until I make the external IO interrupt after DFU.And after I make several time of external IO interrupt , it become normal and don't reset.
  • I feed the dog in the interrupt of app timer. Is that ok?
