Use temperature in Eddystone (TLM)
Hello Everyone,
How could I use the temperature from nrf_temp.h in the Eddystone (TLM) example?
Eddystone (TLM) example:
<nRF5_SDK_v11_0_0 folder>\examples\ble_peripheral\experimental_ble_app_eddystone\
Thanks!
  • please look into the example of temperature sensor in
    nRF5_SDK_v11_0_0 folder>\examples\peripheral\temperature\main.c\
    to understand how you can use the API in nrf_temp.h
  • Thanks, but is it possible to combine the temperature measurement with the oscillator?
    nrf_clock_lf_cfg_t clock_lf_cfg =
        .source = NRF_CLOCK_LF_SRC_RC,
        .rc_ctiv = 16, // Interval in 0.25 s, 16 * 0.25 = 4 sec
        .rc_temp_ctiv = 2, // Check temperature every .rc_ctiv, but calibrate every .rc_temp_ctiv
        .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM,
  • sorry forgot about that, my bad. This module is restricted so you cannot directly access it when softdevice is enabled. You have to use sd_temp_get which is a softdevice API and you can find it in nrf_soc.h.
    /**@brief Get the temperature measured on the chip
     * This function will block until the temperature measurement is done.
     * It takes around 50us from call to return.
     * @param[out] p_temp Result of temperature measurement. Die temperature in 0.25 degrees celsius.
     * @retval ::NRF_SUCCESS A temperature measurement was done, and the temperature was written to temp
    SVCALL(SD_TEMP_GET, uint32_t, sd_temp_get(int32_t * p_temp));
    The value returned by this function is the direct value read from the chip NRF_TEMP->TEMP register. You can use this API even when you have RC clock with calibration on triggered by temp changes.
  • Thanks, that is what i have looking for. Now, I want to send the temperature. Therefore, I have to make 8.8 fixed-point notation (courses.cit.cornell.edu/.../). I have try it, but it does not work. I have program following code:
    int32_t	temp;
    float	temp_f;
    int 	temp_i;
    sd_temp_get(&temp);			//get temperature
    temp_f =  (((float) temp) / 4);		//temperature from 0.25 degrees Celsius to 1 degrees Celsius
    temp_i = ((int)((temp_f)*256.0)); 	//Convert float to fix
    Maybe you could help me a second time. Thanks.
