Cannot get examples to work on 52-DK
Still trying to get anything ta all to work on the nRF52-DK
  • I erased the chip
  • I flashed the soft device "soft_device_s132_v3.3.3" to address 0 and verified
  • built unmodified ~/nordic/SDK_v11.0.0/examples/ble_peripheral/ble_app_beacon/pca10040/s132/armgcc
  • Noticed that this example (andall others) had a serious error. Linker script links it at 0x1c000, but this overlaps the 3.0 soft device. Release notes for soft device say app should start at 0x1f000...examples being wrong is never a good sign...
  • modified linker script to link .text at 0x1f000 and start RAM usage at 0x20002000
  • built it
  • flashed to 0x1f000
  • still no go
  • attaching GDB shows that code runs until a call to SVCALL(SD_SOFTDEVICE_ENABLE... then the code jumps to softdevice, as expected, but it never returns, somewhere in the enable call the CPU HardFaults
SO:
  • What gives?
  • Why the obvious errors in the examples?
  • why does it not work at all?
Actual binary dump of the flash flashed with soft device and compiled unmodified (except linker script) sample app: mega.nz/
  • Assuming you mean softdevice 132 v3.0.0 because there is no v3.3.3
    The obvious error is because SDK 11 was released to support S132V2 not S132V3, it contains the V2 header files and not the V3 header files and the V2 start address and not the V3 start address. So the error is you're using an incompatible softdevice with the SDK/headers/linker scripts you're compiling against.
    If you want to use the V3 softdevice then you need to change the include paths to point to the V3 softdevice headers (which come with the softdevice) and not the V2 ones as well as changing the linker scripts for the different memory requirements of the V3. That will mean you make structures of the correct size to send to all the calls. You may then also get compilation errors because of the changes between V2 and V3 which are documented in the migration guide, or you may find that the defaults work - you should read the migration guide anyway to see what work you have to do to use the V3 softdevice.
    Or use the V2 one the SDK was designed for.
    So "...examples being wrong is never a good sign..." should be "examples not even working should be a sign I've made a mistake". Perhaps your questions could be a little less snarky.
  • latest sdk not working with latest soft device is still rather sad but indeed copying the includes over, fixing renamed functions, and rebuilding got it all working more or less
    thanks
  • I also have a problem migrating to S132 V3. I am using the header files included with V3, but it does not compile. The device_manager.h requires ble_gap_whitelist_t which was defined in bel_gap.h (V2) but is no longer defined in V3!
    ret_code_t dm_whitelist_create(dm_application_instance_t const * p_handle, ble_gap_whitelist_t * p_whitelist);
    Where can I get device_manager.h for S132 V3?
    The project I am using ble_app_template example from SDK11.
    Regards
  • SDK 11 is out for months, S132 v3 is out for... 3 weeks? SDK 12 will support it AFAIK. Some1 from nordic said its release is "just around the corner"
