sht21 with nrf51822 measuring temperature
I am trying to measure the temperature using sht21 sensor with nrf51822. I am using TWI to do this. When I try to send a data to the sensor the application cannot do that. The code for initializing and measuring the temperature is as follows:
static void twi_master_init(void)
ret_code_t ret_code;
//Setup SDA and SCL pin, twi frequency and interrupt priority
const nrf_drv_twi_config_t config =
   .scl                = 18,
   .sda                = 17,
   .frequency          = NRF_TWI_FREQ_100K,
   .interrupt_priority = APP_IRQ_PRIORITY_HIGH
do
    // Unncommend line below to setup TWI without an event handler
    //ret_code = nrf_drv_twi_init(&twiMaster, &config, NULL);
    // Setup TWI with an event handler
    ret_code = nrf_drv_twi_init(&twiMaster, &config, NULL, NULL);
    if(ret_code!= NRF_SUCCESS)
    nrf_drv_twi_enable(&twiMaster);
}while(0);
static void measureTemperature( int* temperature )
ret_code_t err_code;
uint8_t command_address[1] = {0xF3U};
uint8_t read[2] = {0x0000U};
err_code = nrf_drv_twi_tx( &twiMaster, DEVICE_ADDRESS, command_address, sizeof(command_address), false);
SEGGER_RTT_printf(0, "variable value: %d\n", err_code);
//APP_ERROR_CHECK(err_code);
nrf_delay_ms(200);
nrf_drv_twi_rx( &twiMaster, DEVICE_ADDRESS, read, sizeof(read));
*temperature = ROUNDED_DIV( ((21965 * (*read)) >> 13) - 46850, 1000 );
If I uncomment the line "APP_ERROR_CHECK(err_code);" the application crashes. Otherwise the Segger RTT shows that err_code is equal to 3.
What does this mean? How can I solve this error? Any help is appreciated.
Thanks in advance.
Edit: I dig in the code a little bit and found that err_code = 3 means that it is NRF_ERROR_INTERNAL. I have no idea what it means though.
Edit2: I was trying to debug the code by using a twi_event_handler. I noticed that the sht21 is giving ADRESS_NACK error. So the address is not acknowledged by the sht21. I am pretty sure the adress part of the code is correct though?
Edit3: Ok the problem is solved. The datasheet provided for my custom board was mistakenly written the .sda and .scl pins. I verified the correct pins and now it is working.
Thanks
  • This error is generated in nrf_drv_twi.c->twim_xfer where the actual transfer of the data is placed into the hardware.
    The documentation for the API nrf_drv_twi_tx shows that
    @retval NRF_ERROR_INTERNAL If an error was detected by hardware.
    This means that the the function has finished what it supposed to do what there were errors detected in TWI->ERRSRC module. Most probably this is an overrun error which means that you are not reading the data fast enough. The previous data in in RXD register was overwritten.
