I am trying to understand the pstorage to record a log for temperature. In my code, I can call pstorage_init(), and clear a block but when I try to store some data, the application never gets in the pstorage_handler.
I have put some RTT for debugging purposes. From RTT I can see that error1, error2, error3, error5 are 0, NRF_SUCCESS. error4 is never shown because the program cannot reach there.
Here are the main three functions related to this:
static void m_pstorage_init()
uint32_t err_code;
pstorage_module_param_t p_example_param;
// Setup pstorage with 60blocks of 16byte in each.
p_example_param.block_size = 0x4; // recommended to be >= 4 byte
p_example_param.block_count = BLOCK_COUNT;
p_example_param.cb = m_pstorage_handler;
err_code = pstorage_init();
SEGGER_RTT_printf(0, "error_code1: %d\n", err_code);
err_code = pstorage_register (&p_example_param, &m_pstorage);
SEGGER_RTT_printf(0, "error_code2: %d\n", err_code);
static void temperature_timeout_handler(void * p_context)
ret_code_t err_code;
if( count != BLOCK_COUNT){
int temperature;
measureTemperature(&temperature);
uint8_t* a;
a = (uint8_t*)temperature;
pstorage_handle_t block_id;
err_code = pstorage_block_identifier_get(&m_pstorage, count, &block_id );
SEGGER_RTT_printf(0, "error_code3: %d\n", err_code);
err_code = pstorage_clear(&block_id, 4);
SEGGER_RTT_printf(0, "error_code5: %d\n", err_code);
wait = 1;
err_code = pstorage_store(&block_id, a, 4, 0);
while(wait )
power_manage();
SEGGER_RTT_printf(0, "error_code4: %d\n", err_code);
temperature_characteristic_update(&m_tempe_service, &m_pstorage, count);
count++;
void m_pstorage_handler(pstorage_handle_t * p_handle,
uint8_t op_code,
uint32_t result,
uint8_t * p_data,
uint32_t data_len)
switch(op_code)
case PSTORAGE_LOAD_OP_CODE:
if (result == NRF_SUCCESS)
SEGGER_RTT_WriteString(0, "Storage Load Successful!\n");
wait = 0;
SEGGER_RTT_WriteString(0, "Storage Load Failed!\n");
SEGGER_RTT_printf(0, "result: %d\n", result);
APP_ERROR_CHECK(result);
// Source memory can now be reused or freed.
case PSTORAGE_STORE_OP_CODE:
SEGGER_RTT_WriteString(0, "Storage Store Successful!\n");
wait = 0;
SEGGER_RTT_WriteString(0, "Storage Store Failed!\n");
case PSTORAGE_UPDATE_OP_CODE:
SEGGER_RTT_WriteString(0, "Storage Update Successful!\n");
wait = 0;
SEGGER_RTT_WriteString(0, "Storage Update Failed!\n");
case PSTORAGE_CLEAR_OP_CODE:
SEGGER_RTT_WriteString(0, "Storage Clear Successful!\n");
wait = 0;
As far as I understand the error_handler does not break the sd_app_evt_wait() function. Is this correct? How can I solve this issue?
Edit: Ok, I think I solved the waiting issue but there is another error now. The problem was that the app_timer was not allowing any interrupts from softdevice to arise. I simply assigned a flag which changes when the app_timer ticks. Then, I did the pstorage work in my main loop. I am closing this thread and oppening a new one since the error is different now. Anyone who is using the app_timer with the pstorage can use scheduler or just simply assign a flag as I did.
Thanks
